usb charger for the Droid X
This is a discussion on usb charger for the Droid X within the Droid X General Discussion forums, part of the Droid X Discussion category; I just have a question about using other phone chargers for the droid x. when I got my phone it only came with a USB ...
Results 1 to 10 of 10
Thread: usb charger for the Droid X
    3 months registered100 Experience Points31 days registered7 days registered
    Harpoon's Avatar
    36774
    I just have a question about using other phone chargers for the droid x. when I got my phone it only came with a USB cable to charge off of a computer. Before this phone I had a Blackberry curv which had a wall outlet to a micro usb just like the droid x does..
    My question is can I use that wall charger to charge my Droid X ???
    I don't know if there is a certain power raiting I should look for or if all micro usb connection can only carry a certain voltage anyway.
    Thanks for your help
    Harpoon
    Points: 721, Level: 14
    Level completed: 21%, Points required for next Level: 79
    dom707's Avatar
    34087
    44
    droid x uses 5v wich most all other phones use so you should be good. i use an lg cord for charging and it works just fine.
    Points: 4,051, Level: 40
    Level completed: 51%, Points required for next Level: 99
    Overall activity: 10.5%
    sweller's Avatar
    26038
    310
    It should be safe, but the risk is yours. It may or may not work at all. The adapter (I like to call them wall warts), will have rthe specs on it somewhere. If it says it puts out anything significantly greater than 5 volts, I wouldn't use it.
    Points: 68,298, Level: 100
    Overall activity: 30.6%
    Created Album picturesYour first Group31 days registered100 Experience Points7 days registered
    Posting Award
    ashpdwinDX's Avatar
    28747
    Rockford, Illinois
    1,661
    36 times
    It'll work just fine, my dad uses his LG env2 charger to charge his incredible and I've used it for my X. 5v is the standard for USB so pretty much anything that has a micro USB plug will work to charge it.
    The Aperture Science Handheld Portal DeviceIs epic win!!
    I Edit My Posts Alot.
    Points: 2,791, Level: 32
    Level completed: 28%, Points required for next Level: 109
    Overall activity: 1.0%
    h8isgr8's Avatar
    19551
    206
    11 times
    Not all USB supplies are created equally. The DX requires the USB DATA pins to be tied together along with a high value (~200k) pull-up resistor.
    Points: 1,863, Level: 25
    1coopgt's Avatar
    22249
    110
    I use the wall charger from my BB Storm all the time . No problem.
    Points: 3,079, Level: 34
    Level completed: 20%, Points required for next Level: 121
    Overall activity: 4.1%
    glshub's Avatar
    39743
    308
    Mine came with the cord attached to a wall charger. When I use a pc (laptop) to charge it it seems to take forever. Thats probably better for the battery life but I am impatient.
    Sent from my Milestone X using Droid X Forums
    Points: 2,622, Level: 31
    Level completed: 15%, Points required for next Level: 128
    thefuzz's Avatar
    1578
    31
    I use my BB curve charger and its fine.
    Sent from DroidX running Apex 1.41
    Points: 6,135, Level: 50
    Level completed: 93%, Points required for next Level: 15
    Overall activity: 2.6%
    500 Experience PointsCreated Album pictures250 Experience Points100 Experience Points7 days registered
    eric eakin's Avatar
    3548
    Ca
    1,071
    23 times
    i use whatever plugs in, nothing has blown up yet!
    Addicted to technology but don't always get it!
    X 2
    Moderator
    Points: 25,450, Level: 96
    Frequent Poster
    mikeinrichmond's Avatar
    9010
    Richmond, Va
    7,668
    392 times
    Yes a lot of chargers will work to CHARGE the phone, but make sure you also have a Moto/VZW factory usb cable as well in case you need to SBF. Many 'off-brand' USB cords will leave you stuck at the 'waiting for phone' prompt when you try to SBF...
  1. Using gps charger for droid x
    By hemi1300 in forum Droid X Accessories
    Last Post: 07-09-2011, 08:03 PM
  2. Droid X Battery Charger (not phone charger)
    Last Post: 05-09-2011, 08:45 AM
  3. Droid X Touchstone Charger Mod
    By sphan89 in forum Droid X Hacks
    Last Post: 08-16-2010, 05:58 PM
  4. droid x charger vs blackberry charger
    By rubi22 in forum Droid X Help
    Last Post: 08-16-2010, 10:19 AM
  5. Droid X charger question
    By vlade in forum Droid X Accessories
    Last Post: 07-26-2010, 04:58 PM
does a blackberry charger work on a droid x?
facebook mobile login
using droid x usb cable for lg env2
