Wireless Tether OR Hotspot Hack for GB?
This is a discussion on Wireless Tether OR Hotspot Hack for GB? within the Droid X General Discussion forums, part of the Droid X Discussion category; Originally Posted by nycebo Yes, pay Verizon their $20. Elsewise, I've seen it document on many forums that some can get it working, others can't ...
Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 110
Like Tree5Likes
Thread: Wireless Tether OR Hotspot Hack for GB?
  1. #31
    Points: 1,817, Level: 25
    Overall activity: 1.5%
    jmorton10's Avatar
    9150
    310
    Quote Originally Posted by nycebo View Post
    Yes, pay Verizon their $20. Elsewise, I've seen it document on many forums that some can get it working, others can't (patched, wireless tether beta, and all). At this point, I'm almost ready to pull the trigger for verizon's data plan. Can't stand this trial and error stuff. Such a waste of time.
    geez, thanks for the help (not)
    I got it working just fine, no thanks to you.
    ~John
    brandonfish likes this.
  3. #32
    Points: 2,861, Level: 32
    e3zkiel's Avatar
    6303
    California
    193
    11 times
    Quote Originally Posted by jmorton10 View Post
    ~John
    Glad to hear! :-)
    Nokia handheld -> LG flip phone -> Storm -> Droid X
    ROOTED and lovin' it
    running Android
    4.0.4 - currently using Gummy 1.2.0 - 5/9/12 [BETA]
  4. #33
    Points: 3,090, Level: 34
    Level completed: 27%, Points required for next Level: 110
    brandonfish's Avatar
    36744
    Charleston, SC
    224
    7 times
    Quote Originally Posted by Snow02 View Post
    The on-device recording of data use on gingerbread can be avoided by freezing the datamanagerservice.apk and deleting the database in /data/data/com.motorola.android.datamanager/databases.
    However, if you're using an exorbitant amount of data, you're still going to warrant individual attention.
    I have data manager service 1.0 &1.1, should I freeze both? Also, There's something here called "Data collector provider 1.0", what's that all about (doesn't sound good)?
  5. #34
    Points: 17,929, Level: 85
    Snow02's Avatar
    22940
    3,769
    142 times
    Look in the system/app folder. There should be only one datamanagerservice.apk. Rename it to datamanagerservice.apk.bak.
    Do not mess with any of the other dataxxx.apk files. That will break several things.
  6. #35
    bschirf's Avatar
    38752
    @e3zkiel ... That was a bit harsh towards nycebo... wasn't it?
    There are many on this forum that are willing to be helpful to those that are not fully knowledgeable about all of the intricacies of this new OS. Personally, I am thankful for that.
    This is a help forum.... help being exchanged amongst experts... as well as help being shared amongst others, allowing us all to become more knowledgeable.
    The Android OS, unlike its half-brother for servers (*nix) is currently gaining MASS appeal partially because of its openness and HELPFUL forums... and hopefully will continue to gain marketshare.
    And if enough users desire tethering and learn from others how to properly do this w/o snobbish remarks... then ultimately the market will drive the capability and eventually it will becomestandard a standard feature... but first, forums such as this must strive to be HELPFUL and accessible to the masses, otherwise the Android will go the way of Betamax, Blu-Ray, OS2, etc...
    My $0.02
  7. #36
    Points: 5,992, Level: 50
    JNEHAMA's Avatar
    28370
    Long Island New York
    1,205
    65 times
    @snow02 two brief questions. Is there anything else besides tethering that gives a uid of 0 because I do not tether. Attempted it once just after upgrading to 596 to check if it was blocked. I then got rid of the 3 apps I tried. I wear into the database and under usage at irregular intervals there is a uid of 0. It is always one line only but can be from every 10lines to every 30 lines.
    Second question is must I delete the database or does renaming work for that kind of file. I do not like doing irreversible things unless neccessary.
    Thanks.
  8. #37
    Snow02's Avatar
    22940
    3,769
    142 times
    Anything that uses data as root will show up as uid 0. I haven't noticed anything other than tethering that does, but of course it's possible. I have no idea what that would be though.
    To recreate the database, just unfreeze datamanagerservice.apk and reboot. It will be automatically generated.
  9. #38
    JNEHAMA's Avatar
    28370
    1,205
    65 times
    Here is a screenie of the new database generated since I renamed it 30minutes ago. You see the 0 towards the top. I have definitely not tethered. So I guess it's an fyi. Thanks for the help.
    Attached Images Attached Images
  10. #39
    Points: 10,255, Level: 67
    Backnblack's Avatar
    26
    2,816
    139 times
    Quote Originally Posted by JNEHAMA View Post
    Seems to me that just means you have a root app that is using data...
    Only the Skilled Survive
    1. Never be unarmed.
    2. See Rule #1
  11. #40
    JNEHAMA's Avatar
    28370
    1,205
    65 times
    Quote Originally Posted by Backnblack View Post
    Then how can it differentiate tethering from any other root app? I can see how this helps them pick up who is rooted. But root is not illegal but tethering might be considered theft of service.
  1. Wirless Tether? 3g HotSpot? I can't get either one to work on GB. Please help.
    By rjizle4shizl in forum Gingerbread Development and Hacking
    Last Post: 04-26-2011, 08:57 AM
  2. No 3G Hotspot Tether
    By joehempel in forum Hacking Help
    Last Post: 02-25-2011, 05:25 AM
  3. 3g hotspot and tether patch
    By droiding in forum Droid X Hacks
    Last Post: 01-07-2011, 05:10 PM
  4. 3G hotspot vs Wireless Tether vs Barnacle
    By armyjeffries in forum Droid X Apps
    Last Post: 12-19-2010, 01:24 PM
  5. hotspot vs wireless card
    By doug494 in forum Droid X General Discussion
    Last Post: 08-05-2010, 12:24 AM
com.motorola.android.dm.service
dm service android
droid 3 hotspot hack
droid 3 hotspot patch
droid x hotspot gb trick
droid x hotspot hack
gingerbread hotspot hack
hotspot hack droid x
wireless tether apk gingerbread
