Just loaded Drew Garen's Hateraid for .596..... Heres what I think.
This is a discussion on Just loaded Drew Garen's Hateraid for .596..... Heres what I think. within the Droid X General Discussion forums, part of the Droid X Discussion category; @Akeezy: You really need to contact Drew and ask to be a Beta Tester. I'll put in a good word for you. - You can ...
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 56
Thread: Just loaded Drew Garen's Hateraid for .596..... Heres what I think.
    Points: 1,313, Level: 20
    Level completed: 13%, Points required for next Level: 87
    SpookyJ's Avatar
    31501
    61
    - You can lead a horse to water, but you can't make him think.
    Points: 1,868, Level: 25
    Overall activity: 3.2%
    akeezy's Avatar
    35474
    289
    17 times
    Haha thanks for the vote of confidence. I was about to apply last week but when I opened the website he had just posted about possibly leaving the DX community. But I guess now that he's staying I should do it.
    Points: 3,013, Level: 33
    Level completed: 76%, Points required for next Level: 37
    Artisticsoul79's Avatar
    21379
    Pleasanton, California
    352
    Quote Originally Posted by xjeepguy View Post
    WOW..... Thats all I have to say. This rom is as smooth as I have ever seen, and FAST. I try roms all the time. Usually I try them, and if I like them, I may use it for a while and try something different. This rom on the other hand, I like so much I felt the need to make a thread about it. As I have mentioned before, I am a fan of Drew's work. I may just like this better than broodcomb. Very cool. As always, it is a simple look, with a smooth, finished feel. Just awesome.
    Does your calendar work on Hateraid?
    No Signature Needed..
    SpookyJ's Avatar
    31501
    61
    Quote Originally Posted by akeezy View Post
    I just sent him an email telling him about you, using your forum name, so be sure to reference that when you apply.
    Have a good day, my friend.
    - Absit invidia.
    akeezy's Avatar
    35474
    289
    17 times
    Thank you very much. I did an application this afternoon.
    patrick72's Avatar
    22485
    55
    Just flashes hateraid 1.5 and all is good except sync icon in status bar. It will not got away. Any thoughts? Did not data wipe
    Hateraid 1.5
  8. #17
    Points: 4,487, Level: 42
    Level completed: 69%, Points required for next Level: 63
    Overall activity: 1.2%
    rudyy's Avatar
    30693
    california
    738
    11 times
    Quote Originally Posted by patrick72 View Post
    Hateraid 1.5
    i flashed it a couple days ago, and had the same problem.
    found a thread suggesting one solution, but it dint work.
    also, could not add to my calendar (though that problem first appeared on liberty v0.6), so i restored to v0.6.
    also, somewhere in there, root call blocker stopped blocking and has not recovered, even with fresh installs so i had to go back to mr. number call blocker.
    seems little things are starting to add up suddenly, and i don't really want to sbf and start fresh.
    running gingerbread 602 SBF
  9. #18
    akeezy's Avatar
    35474
    289
    17 times
    Quote Originally Posted by rudyy View Post
    What solution did you try that failed? Was it to do a factory wipe and go through the setup again? The calendar issue has been fixed on hateraid 1.5. I don't know anything about the call blockers though
  10. #19
    rudyy's Avatar
    30693
    california
    738
    11 times
    someone said to delete all email apps except gmail and then reload.
    besides gmail i only have att, through yahoo, so i deleted and reinstalled; nothing.
  11. #20
    akeezy's Avatar
    35474
    289
    17 times
    That's the first I'm hearing of that method. I usually just do a factory wipe and go through setup again. That's the common method that I've seen
  1. .596 ROMs by Drew Garen?
    By cclauss777 in forum Gingerbread Roms
    Last Post: 06-08-2011, 10:25 PM
  2. Drew Garen ROMS and GB .596
    By matjmonk in forum Gingerbread Roms
    Last Post: 06-08-2011, 06:39 PM
  3. Best drew garen rom?
    By jarrod138 in forum Gingerbread Roms
    Last Post: 05-27-2011, 05:28 PM
  4. Drew Garen
    By fersayken2 in forum Gingerbread General Discussion
    Last Post: 05-18-2011, 08:43 PM
haterade 2 rom reset
hateraid 15 screenshots
hateraid 2
hateraid 2 drew garen
hateraid 2 rom
hateraid droid x download
hateraid rom
hateraid vs liberty
how to download hateraid 1.5 droid x
rubix rom for596 gb
