Wanting to factory reset, but what all will it erase and how can I save some stuff
This is a discussion on Wanting to factory reset, but what all will it erase and how can I save some stuff within the Droid X General Discussion forums, part of the Droid X Discussion category; When you factory reset, is EVERYTHING gone? the only thing i am really concerned about is my contacts. i have over 400 contacts that all ...
Results 1 to 10 of 17
Thread: Wanting to factory reset, but what all will it erase and how can I save some stuff
    Points: 1,334, Level: 20
    Level completed: 34%, Points required for next Level: 66
    devdroid's Avatar
    23115
    87
    When you factory reset, is EVERYTHING gone? the only thing i am really concerned about is my contacts. i have over 400 contacts that all have pictures synced with facebook and as i have read you can no longer do this and i dont want to lose them, also will it erase the stuff on my sd card? ( pic's and stuff downloaded ) ? is there a way i can save my contacts/contact pics but still factory resety
    RS Team Leader
    Points: 26,927, Level: 97
    Level completed: 58%, Points required for next Level: 423
    Overall activity: 99.9%
    Activity Award
    popcenator's Avatar
    21238
    Omaha, NE
    8,258
    179 times
    Factory reset will wipe all your data, you will be able to resync Facebook contacts once you get all your contacts back and sign in to Facebook, I believe.
    If all you're really worried about is your contacts, sync those with your Google account via settings -> Accounts, or you can use Backup Assistant by Verizon. You can also export your contacts list to your SD by going into your contacts and pressing the first hard key (leftmost key) and selecting Import/Export.
    Xponentially Better
    Guest Xponentially Better's Avatar
    Everything will be erased except what is on your sd card.
    Points: 19,500, Level: 88
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    Go here to make sure your contacts are there...http://www.google.com/contacts. If they are there when you sign in, they are synced and you should be good.
    Can also export to the sd card as an extra backup, as pop mentioned.
    devdroid's Avatar
    23115
    87
    Thank you so much !!!!
    Points: 1,036, Level: 17
    Level completed: 36%, Points required for next Level: 64
    Overall activity: 0.0%
    tgs's Avatar
    12748
    23
    So assume we remove the SD; mostly because it shouldn't factor into these questions. When performing a factory reset, which files/folders are affected exactly?
    Are there any leftover objects that we should (by should, I mean if we want a true stock phone setup again and are being OCD about it) remove?
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    Quote Originally Posted by tgs View Post
    You don't need to remove the sd card, but it won't affect it if you do. If you're not rooted, factory reset will wipe all user data and you'll be completely stock.
    If you are rooted, it depends what you've done with root...
    devdroid's Avatar
    23115
    87
    if i want to save some apps (games mostly with highscores on them, and dont want to redownload them again) i can just move to sd card, wipe phone ,and move them back to phone when im done? i read that factory resetting your phone on gb helps it
    Points: 1,009, Level: 17
    Level completed: 9%, Points required for next Level: 91
    richielwolf's Avatar
    26727
    23
    I too would like some info on this. I have appbrain loaded. I've searched and am still not sure about how to backup apps/contacts and wipe clean. Or even how to wipe it for that matter.
    Points: 2,707, Level: 31
    Level completed: 72%, Points required for next Level: 43
    holly's Avatar
    19007
    SF Bay area
    587
    13 times
    There are apps on the market that can help back up all your apps and settings - MyBackup Pro is one- but wait for others to chime in here. In any case as long as you have auto restore and back up my data checked your apps will all re-download after you log back into Google. Look under settings >privacy.
    Keep in mind however it's likely third party apps that are giving people problems with gingerbread. I'd strongly suggest re-downloading apps one by one. I did this and it's not that big of a deal honestly. Take you two or three w-fi sessions maybe depending on how many apps you have. You will need to Google " how to prevent auto re-download of apps after factory reset " and you can then learn how to do it. Essentially before you do factory reset you uncheck auto restore AND uncheck back up my data. Then, when your phone starts to take you step by step through the activation process (post reset) you skip all the adding accounts etc., wait for home screen to load and go directly to settings where you again UNCHECK auto-restore and back up my data. You may have to first check Back up my data in order to uncheck auto restore - sounds confusing I know but it's really simple. Just make sure both are unchecked again. At that point apps will NOT re-download and you can then enter your google account info. Also look up same topic over at the Motorola support forums. I followed these steps when I took the ota and am enjoying virtually problem free gingerbread.
    Edit: Afterwards I noticed I still had my Robo Defense levels/points. I didn't know it at the time but that app had put that info on the SD card. So I guess if you are savvy about these kind of things you can check your SD card files beforehand.
    Sent from my DROIDX
  1. Replies: 1
    Last Post: 05-22-2011, 01:01 PM
  2. reset to factory
    By th0mas in forum Droid X General Discussion
    Last Post: 04-02-2011, 03:08 PM
  3. Need help with factory reset.
    By Integraoligist in forum Droid X General Discussion
    Last Post: 03-21-2011, 08:29 PM
  4. How to to do factory-reset?
    By MDDC in forum Droid X Help
    Last Post: 11-12-2010, 03:49 PM
  5. factory reset
    By buzzkill in forum Droid X Help
    Last Post: 09-12-2010, 09:24 PM
does a factory reset delete pictures
does factory reset delete bookmarks
does factory reset delete contacts
does factory reset delete pictures
will a factory data reset erase my pictures
will a factory reset delete my pictures
will a hard reset delete my contacts
will a master reset delete my contacts
will factory data reset delete my pictures
will factory reset delete contacts
