Wanting to factory reset, but what all will it erase and how can I save some stuff
This is a discussion on Wanting to factory reset, but what all will it erase and how can I save some stuff within the Droid X General Discussion forums, part of the Droid X Discussion category; One thing to note too is if you have a password/account manager. I was using Moola (lite) for my bank info and all the data ...
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Wanting to factory reset, but what all will it erase and how can I save some stuff
    Points: 2,284, Level: 28
    Level completed: 90%, Points required for next Level: 16
    Tagger Second Class250 Experience Points100 Experience Points31 days registered7 days registered
    SVDroidDude's Avatar
    18092
    Everett-NW Hood
    526
    13 times
    One thing to note too is if you have a password/account manager. I was using Moola (lite) for my bank info and all the data is gone...it did not save to SD which is very poor. On the other hand, Pocket (a password manager) backs up to Dropbox so when I re-installed it, it found all my data perfectly.
    I should have gone through all my apps that had data that could be important but unfortunately my phone was unresponsive after the GB OTA and I had no choice but to factory reset. I can say this, my phone is working fantastic now.
    Points: 646, Level: 12
    Level completed: 92%, Points required for next Level: 4
    Overall activity: 0.8%
    OcalaFlGuy's Avatar
    32422
    28
    Hear me now and believe me later.
    On an unrooted phone, MyBackupPro WILL NOT save your game scores/progress at least on Angry Birds and Skies of Glory. Say Baabye.
    (And that IS with backing up both Apps and Data. <Now, how in the hell your scores and progress don't fall under one of those two, I don't know.>)
    I do believe there is a way to save them if you are rooted. I don't know what that is though.
    Bruce in Ocala, FL0-waaaangh lost all my hard earned planes in SoG
    Points: 935, Level: 16
    Level completed: 35%, Points required for next Level: 65
    tr501's Avatar
    11867
    Ohio
    17
    I think I need to do the factory reset in order to clear up some crazy stuff that has occurred since the OTA upgrade. My question is if I re-install the app Lookout after the reset it should transfer all the backed up stuff right back to the phone shouldn't it ?
    You can recover lost files after droid phone factory reset, here's a step by step guide
    how to recover data from android phone after factory reset
    I was having success with this guide last time, it's easy to follow and works well for me. Hope that it helps you too.
    Banned
    Points: 9,438, Level: 65
    Level completed: 30%, Points required for next Level: 212
    DroidlynnXDoes's Avatar
    56858
    Mar 2012
    In a world that doesn't
    3,118
    16 times
    I just back everything up to my laptops file manager (I use windows 8 which I actually love using), and then do the FDR. I have so much media files on my Droids (I have 4, only 3 are live ones, one is fake, and only my Razr Maxx HD is active), that I copy them to my laptop then burn cd/DVD 's in case something happens to my lappy
    My fake OG RAZR is doing all the talking while Maxx Swypes
    Banned
    56858
    Mar 2012
    3,118
    16 times
    Then after the FDR I copy everything back to my Droids. I have 5 or 6 sd cards. 2 36gb 3 16gig, and 1 8 gig. I buy them when I'm able to
  8. #17
    Banned
    56858
    Mar 2012
    3,118
    16 times
    Remember that an FDR won't touch your sd card unless you tell it to. It won't clear the sd card if you go into stock recovery to do the FDR. To get into stock recovery, power off your X, or simply do a battery pull, then press home and hold and whilst holding home press power and only release power when Motorola M appears if you changed your boot logo it will be something different, but don't release home until you see Andy the green Droid with a yellow and black ! Icon with him, then press both volume buttons and highlight and select factory reset data wipe (something like that) then wait for it to be done and highlight and select reboot. Your X will walk you thru the process of setting everything up again. I always back up my contacts with both Google and VZW backup assistant to ensure I won't lose anyone's number. If you have Google back up your account your contacts should be there. But if you haven't your X will ask you if you want it backed up, tell it yes. All your Google play data, apps download history, Gmail, contacts, files on your Google account should be backed up. Saves time and energy because you don't have to input everything all over in case you have to do another FDR
  1. Replies: 1
    Last Post: 05-22-2011, 12:01 PM
  2. reset to factory
    By th0mas in forum Droid X General Discussion
    Last Post: 04-02-2011, 02:08 PM
  3. Need help with factory reset.
    By Integraoligist in forum Droid X General Discussion
    Last Post: 03-21-2011, 07:29 PM
  4. How to to do factory-reset?
    By MDDC in forum Droid X Help
    Last Post: 11-12-2010, 02:49 PM
  5. factory reset
    By buzzkill in forum Droid X Help
    Last Post: 09-12-2010, 08:24 PM
does a factory reset delete pictures
does factory reset delete bookmarks
does factory reset delete contacts
does factory reset delete pictures
will a factory data reset erase my pictures
will a factory reset delete my pictures
will a hard reset delete my contacts
will a master reset delete my contacts
will factory data reset delete my pictures
will factory reset delete contacts
