Newb's read this....common misconceptions, errors, and commonly asked questions
This is a discussion on Newb's read this....common misconceptions, errors, and commonly asked questions within the Droid X General Discussion forums, part of the Droid X Discussion category; A nandroid is done through clockwork recovery in the backup and restore menu. Its a complete backup of the entire system, settings and all, not ...
Page 10 of 10 FirstFirst ... 8 9 10
Results 91 to 99 of 99
Like Tree14Likes
Thread: Newb's read this....common misconceptions, errors, and commonly asked questions
  1. #91
    RS Team Leader
    Points: 19,434, Level: 88
    Level completed: 17%, Points required for next Level: 416
    Overall activity: 44.9%
    popcenator's Avatar
    21238
    Omaha, NE
    7,802
    112 times
    A nandroid is done through clockwork recovery in the backup and restore menu. Its a complete backup of the entire system, settings and all, not just the apps.
    on the move..
  3. #92
    Points: 192, Level: 3
    Level completed: 84%, Points required for next Level: 8
    Overall activity: 4.3%
    100 Experience Points7 days registered
    grege3g's Avatar
    53760
    Dec 2011
    50
    In titanium back never restore system apps it will cause your phone to do back flips just restore regular apps + data and run batch
  4. #93
    Points: 644, Level: 12
    Level completed: 88%, Points required for next Level: 6
    Overall activity: 1.1%
    aknox077's Avatar
    50069
    Oct 2011
    Cleveland
    67
    System Apps or System Data?
  5. #94
    grege3g's Avatar
    53760
    Dec 2011
    50
    Well let me explain the system apps that run on miui specific rom are running and functional if you restore system apps + data from liquid smooth they are not going to agree you are going to have alot of force closes and even you screen going black because the data is not matching
  6. #95
    Points: 3,900, Level: 39
    Level completed: 67%, Points required for next Level: 50
    Overall activity: 68.4%
    casper55117's Avatar
    56375
    Mar 2012
    minnesnowda
    992
    11 times
    Quote Originally Posted by Nerdslogic;326380
    [B
    Anti Virus=[/B] there is NO need for Anti Virus on your device as of yet. Unless of course you want to slow it down with more useless software
    im sorry i have to call you out on this. ANYTHING with an os can get a virus the only things that cant are "live cd's"
  7. #96
    Points: 143, Level: 2
    Level completed: 86%, Points required for next Level: 7
    Overall activity: 3.4%
    mikecox's Avatar
    57015
    Mar 2012
    18
    I found this sticky thread helpful; but as a "newb" I was sometimes baffled by the use of so many unexplained acronyms. SBF comes to mind. I know what it is now, but what does it mean? Since this thread is directed at newb's it should assume that these acronyms are all Greek to us and should be accompanied by the phase they were created from; if they are to help those for whom this threat was created; so we wont keep asking the same questions over, and over, and over and over
  8. #97
    Points: 747, Level: 14
    Level completed: 47%, Points required for next Level: 53
    baboon619's Avatar
    34882
    San Diego
    Thank you for this light reading!
    I rooted my DX and 1st thing to do is perform a nandroid backup so I next installed... DroidX Bootstrap & Rom Manager.
    Yes I see now that this thread says to install D2 Bootstrap.
    Question#1 Can I just install the D2 bootstrap over the Dx Bootstrap ?
    Also within Rom Manager when I select backup it asks which recovery I want to install with a list of choices...
    Question#2 Which do I choose here.... DroidX or DroidX 2nd-Init?
    I have been reading the differences and seems like I should be selecting 2nd-Init
    DX OTA .605 build, now rooted.
    Where's my Humanoid
  9. #98
    Points: 4,445, Level: 42
    Level completed: 48%, Points required for next Level: 105
    Overall activity: 63.0%
    jeems's Avatar
    40702
    1,116
    19 times
    Quote Originally Posted by baboon619 View Post
    You can use DX bootstrap, but D2 works better. I would uninstall DX if you are going to use D2. When updating the version it depends on what kind of rom you are on. For stock, you just want Droid X. If you install a 2nd init ROM choose the 2nd init version. (2nd init would be gummy, miui, CM7 or 9, etc)
    edit: if you are going to stay on stock rooted, I don't think you need to update it. You probably won't need to update it until you install a rom.
    Check out my themes:
    Simple Sideways - MIUI lockscreen
    Simple Sideways Dark
    Touch of Green - Vortex RC1
    Christmas theme
    (in case you miss it) - Vortex RC1
  10. #99
    baboon619's Avatar
    34882
    San Diego
    Ok, uninstall the Dx Bootstrap and install the D2. I kinda like it when things run smoother.
    Not planning on staying stock. Probably go with CM7 first go around.
    (Was thinking of trying a few roms and seeing if any of them clear up my 2 year old problem and 3 different phones.)
    Where's my Humanoid
  1. Common GB install questions answered
    By fezrock in forum Gingerbread General Discussion
    Last Post: 04-20-2011, 12:30 AM
  2. A few random newb questions
    By hobocoe in forum Hacking Help
    Last Post: 04-06-2011, 09:55 PM
  3. Replies: 17
    Last Post: 12-02-2010, 07:25 PM
  4. I have some questions for a Droid X newb
    By mgd6912 in forum Droid X Help
    Last Post: 08-06-2010, 10:40 AM
  5. Questions from major droid newb
    By mr187 in forum Droid X Help
    Last Post: 08-06-2010, 01:43 AM
bootstrap equivalent for droid x2
chromebook offline misconception
common droid x problems
common problem on ginger dx?
common problems with droid x
do i need to have usb plugged in using z4root on droid x 2.3
does bootstrap void warranty
does lookout security cause problems with digital clocks in the droid x
driver needed for droid x to run .jar
droid x common problems
geenral misconception on android
is lookout necessary on droid
lookout for gingerbread
lookout necessary android
lookout problems gingerbread droid x2
