The crackberry I had before couldn't do much right, but it did predict and correct better. It also capitalized I, but the stock one one my X doesn't. I don't like swype yet so I don't know if it will or not. TIA.
This is a discussion on Has anyone found a better keyboard and autocorrect than the stock? within the Droid X General Discussion forums, part of the Droid X Discussion category; The crackberry I had before couldn't do much right, but it did predict and correct better. It also capitalized I, but the stock one one ...
better keyboard (2.99) or swiftkey beta (free for now)
All men by nature desire to know -Aristotle
New to Android? Click Here!
All-In-One POST ROOT Thread
Droid X Hacking Checklist
SBF without RSDlite
you can add words to the user dictionary and better keyboard will use that
SBF without RSDlite
smart keyboard pro is excellent, and it also has a longer spacebar.
Check out the HTC IME keyboard that has been developed over several months at XDA. That's what I used on my Droid (and installing it again for my wife on hers). I am pretty happy with Swype on my X for now.
