Display sucking up my battery.
This is a discussion on Display sucking up my battery. within the Droid X General Discussion forums, part of the Droid X Discussion category; The display consumes a huge chunk of battery power right? So if I keep my screen animations to a complete minimum and have as much ...
Results 1 to 6 of 6
Thread: Display sucking up my battery.
    250 Experience Points7 days registered100 Experience PointsTagger Second Class
    WhiteGrizzly's Avatar
    36371
    Cleveland, Ohio
    52
    The display consumes a huge chunk of battery power right? So if I keep my screen animations to a complete minimum and have as much black and white as possible will that save juice?
    Points: 3,256, Level: 35
    Level completed: 38%, Points required for next Level: 94
    Overall activity: 17.3%
    swalker's Avatar
    14966
    648
    16 times
    just keep display down as much as possible and it helps alot
    Rescue Squad
    Points: 28,311, Level: 98
    Level completed: 97%, Points required for next Level: 39
    Leach19m's Avatar
    31277
    Washington
    7,053
    234 times
    Im not sure that having different class colours has any effect on battery usage... isn't the majority of power consumed by the screen by the backlight? I could very well be wrong through. Regardless of that, the easy way to reduce battery usage by the display is to turn auto brightness off, and have it set as dim as you can use it with
    Yup, some research confirms out. LCDs dont actually produce any light themselves. The pixels are just molecules aligned in different ways to produce different colours. So, black, white, red, or magenta... same power usage. If there is any difference at all, black would actually require more power to produce as it requires the activation of the liquid crystal molecules to obstruct the light
    Sent from my Droid X, which Netflix thinks is an HTC Vision!
    3 months registered100 Experience Points31 days registered7 days registered
    bdab951's Avatar
    36807
    Southern California
    8
    If you have a Live Wallpaper it will suck up alot more of your batter than if you had a regular wall paper, I also heard that the more widgets you have up will also make your battery go faster as well.
    jerofld's Avatar
    34284
    325
    Using black on your background does not help with LCD screens, such as what the DX has. LCD screens use a single backlight to light the entire screen. Using black helps power consumption on AMOLED screens, where each LED is it's own backlight.
    To conserve power, keep brightness at absolute minimum you need for viewing. Turn it completely off if you can see the screen. Other than that, the only thing that reduces the display's power consumption is...turning off the display when you don't need to use it.
    Advocate X Achievements:
    The persuader's Avatar
    12986
    Maine
    5,603
    66 times
    The Widgets and Live Wallpaper that we all use on our phone..... IS....most of the Issues with Battery Live...But our Phones look Awesome... I really dont mine so much with my Battery Life...I Bought another Battery so I can Enjoy my Phone without B******* about my Battery Life all the time...Plus, I will take Performance and Looks over Battery Life any day...
    Our usage for the way we all use Our Phone...Well, it would be one Hellva Big Battery to support what were all expecting from these Mini Computers...I have Two 3500 Batteries...If I can get 9 Hours with the 3500 Battery...Thats a good day for the way I use it and what I have going with Widgets and Misc stuff... IMO...
    Its Bubba
    "Stubborn In You're Bones"
  1. Display Brightness
    By WhiteLabelDon in forum Droid X General Discussion
    Last Post: 04-24-2011, 01:42 AM
  2. Display brightness
    By dropd1us in forum Droid X General Discussion
    Last Post: 01-20-2011, 07:32 PM
  3. Detailed Battery Usage Display Issue
    By ihodgex in forum Droid X Help
    Last Post: 10-31-2010, 07:14 PM
  4. Battery drain from display, possible app?
    By Kithro in forum Droid X Help
    Last Post: 10-22-2010, 01:12 PM
  5. Car mount sucking @ charging?
    By SmokeyBear911 in forum Droid X Accessories
    Last Post: 09-19-2010, 06:12 AM
display usin all of tje battery
display using battery android droid x
droid display using too much battery
droid x display using battery
droid x2 display using all the battery
my droid is sucking battery power
phones display using all battery
what is sucking up my htc one x battery
why is my driodmax using so much battery power
why is the display on droid x taking so much battery power
