Can a rooted droid place & receive voip calls without a voice plan?
This is a discussion on Can a rooted droid place & receive voip calls without a voice plan? within the Droid X General Discussion forums, part of the Droid X Discussion category; I am considering purchasing a used droid x. I really don't know the pros or cons of rooting, but it may allow me to access ...
Thread: Can a rooted droid place & receive voip calls without a voice plan?
    I am considering purchasing a used droid x. I really don't know the pros or cons of rooting, but it may allow me to access internet data with a hotspot device, or maybe, as its own hotspot without a voice plan, and with a data plan with Verizon, or Metro PCS, if they will allow me to connect to their service from the Seattle neighborhood.
    If I can use the droid x as a hotspot and have only a data plan, do you know anything about placing and receiving VOIP calls on it, be it with google voice, skype, or ??? If the phone app is activicated will it always ring when a call comes in, just like my landline?
    Will I be able to tether it wirelessly to more then one PC?
    Will it be able to multi-task (ie. place or receive a call while doing a search)?
    Thanks for your time. If you can't answer these questions, maybe, you can direct me to a place that can answer them.
    jerofld's Avatar
    34284
    325
    I am not aware that you could get 3G service without a voice plan. Unlike how home based internet works. Like I don't have cable, or even basic cable, but I have the internet netflix/hulu.
    There are ways of getting a DX to work on PCS and Cricket, but I'm unsure how those places work with data and if you need voice.
    Points: 1,955, Level: 26
    duro78's Avatar
    20949
    169
    No it can't, the most it can do is connect to wifi
    Droid X - Rooted Z4 - OTA 340 - Gummy Jar 2.5 - Theme Watermark - ADW Ex
  1. NEWB Needs help with Google Voice and VOIP
    By fsand in forum Droid X Help
    Last Post: 03-02-2011, 07:49 PM
  2. Can't make or receive calls
    By Koopa Troopa in forum Droid X Rescue Squad
    Last Post: 01-05-2011, 01:56 AM
  3. google voice voip problems
    By dmarth10 in forum Droid X Help
    Last Post: 10-25-2010, 12:42 PM
  4. Droid wont receive, or make calls or texts, or internet
    By fighterpilot53 in forum Droid X Rescue Squad
    Last Post: 10-21-2010, 02:51 PM
can you make calls with a rooted android?
free calls on rooted android
free voip android root
receive voip calls on android
rooted android voip
use droid without service for voip
use droid x without service
using droid x without voice plan
voip rooted android
voip rooted phone
