Adding convenience to Android Widgets and Home screen setups
This is a discussion on Adding convenience to Android Widgets and Home screen setups within the Droid X General Discussion forums, part of the Droid X Discussion category; If any of you have used Launcher Pro or ADW and flash Roms every now and then you're most likely familiar with the pain of ...
Thread: Adding convenience to Android Widgets and Home screen setups
    Points: 1,448, Level: 21
    Level completed: 48%, Points required for next Level: 52
    cizzlen's Avatar
    2718
    43
    Lightbulb Adding convenience to Android Widgets and Home screen setups
    If any of you have used Launcher Pro or ADW and flash Roms every now and then you're most likely familiar with the pain of re-adding all your widgets and settings. As we know Android has a slight limitation with widgets which just so happens to be one of the greatest features available on smartphones these days.
    So what IF Google could incorporate a way for us to preserve our home screens and settings as is? Maybe we as a community can use our voice to gain some acknowledgment on this. I'm sure Google can pull this off if we can manage to bring it to their attention.
    Correct me if I missed anything and voice your ideas!
    Backnblack's Avatar
    26
    2,818
    136 times
    Sounds like a Dev problem and not a Google problem.
    Only the Skilled Survive
    1. Never be unarmed.
    2. See Rule #1
    Points: 15,508, Level: 80
    Level completed: 32%, Points required for next Level: 342
    Overall activity: 7.1%
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,144
    201 times
    Quote Originally Posted by cizzlen View Post
    Both ADW and Launcher Pro have backup and restore options for your homescreens and settings. The only thing it can't restore is your widgets, but your icons, dock, settings, etc. can all be restored.
    Or if you backup your launcher's data with Titanium backup, it would restore your homescreens and settings too...
    And Mybackup Pro has options to backup and restore homescreens if you are using the stock launcher...
    cizzlen's Avatar
    2718
    43
    It's a Google issue: "problem loading widget" there is nothing Devs can do about it. In the Launcher Pro menu before doing a restore it's mentioned "due to limits in Android". Unless it is possible to keep your home screen widgets without re adding them after a restore then I just didn't know about that but I'm 90% percent sure that you can't do this with Android. I've flashed plenty of Roms and restoring my home screen was one of the pains that comes with it. What if we could hit restore and everything was back to normal? That is my main point here which is to simply add convenience. Just an idea.
    Edit: So MyBackup does let you restore your home screens back to normal and apparently it's just an issue with 3rd party home screen replacements?
  1. adding pic to pull down screen
    By dwgreenstreet in forum Droid X Themes
    Last Post: 04-30-2011, 11:42 AM
  2. Locking home screen widgets
    By ffr3247r in forum Droid X Themes
    Last Post: 01-15-2011, 06:02 PM
  3. Replies: 12
    Last Post: 01-05-2011, 04:56 PM
  4. App for adding home screens
    By niteman11 in forum Droid X Apps
    Last Post: 09-24-2010, 11:58 AM
  5. Guide To Organizing Your Android Home Screen
    By Abe21599 in forum Droid X General Discussion
    Last Post: 08-11-2010, 12:56 PM
adding widget to launcher droid charge
android backup widgets
android home screen ideas
android home screen setups
android widget limitations
best android home screen setups
best android screen setup
best android screen setups
best ways to set up home screen for your droid x
convenient android widgets
droid setups
how can i restore my android home profile
how do i get droid homescreen back
how to restore widgets on Droid x
launcher pro setups
