Handcent loading slow?
This is a discussion on Handcent loading slow? within the Droid X General Discussion forums, part of the Droid X Discussion category; When i click on handcent, its black, then you can see a page of the top conversations i am having, but when you scroll down, ...
Results 1 to 10 of 10
Thread: Handcent loading slow?
    3 months registered31 days registered250 Experience Points7 days registered100 Experience Points
    mittens's Avatar
    426
    Huntsville, AL
    103
    When i click on handcent, its black, then you can see a page of the top conversations i am having, but when you scroll down, its very JUMPY/lagging, and you have to kinda keep trying to go farther down the list until it forces it to load everything, then you can slide up and down like a champ...any way to make this not happen?
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    Quote Originally Posted by mittens View Post
    There was a recent update - did you load that. It was also suggested in another thread to uninstall and reinstall to see if that fixed the issues...
    Points: 7,208, Level: 56
    500 Experience Points250 Experience PointsCreated Album picturesThree Friends100 Experience Points
    didiwags's Avatar
    55
    Minnesota
    1,450
    21 times
    Ditto!! There is an update!! I never DL'd the faulty one but when I did DL the new updates, it showed both of them!!! My handcent works fine!!
    Droid Does!!!
    Created Album pictures250 Experience Points7 days registered100 Experience PointsTagger Second Class
    thecta's Avatar
    2899
    Southwest MO
    233
    16 times
    I have done a reset and the updates and everything works fine now with Handcent.
    mittens's Avatar
    426
    Huntsville, AL
    103
    I just did another update, but i will try to uninstall and redo it with the updated one. see what happends.
    Points: 27,939, Level: 98
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    if anyones still having this problem, delete cache or some of the texts. always works for me
    20,509
    885 times
    Quote Originally Posted by Abe21599 View Post
    Abe - that would save the uninstall wouldn't it? And by clear cache you are indicating that they go into manage applications (homescreen - settings - applications) and clear cache there (especially if unrooted)? Or will HistoryEraser clear text app cache?
    mittens's Avatar
    426
    Huntsville, AL
    103
    The problem is i always hit the back key to get back tot he home screen, if i hit the home screen it works fine. after the first time its been loaded.
    also with a task killer every time the screen was locked/black it killed the app and had to reload it.
    Moe's Avatar
    4749
    Indianapolis, IN
    10
    TTT
    I am having this exact issue, except it only started after installing K-9 Mail. Looking at the "Running Resources," these two programs are among my top memory hogs. The issue is noticeable with as few as one thread in Handcent, and I have already tried clearing cache and reinstalling. Any other alternatives short of getting rid of K-9?
    Points: 5,228, Level: 46
    Level completed: 39%, Points required for next Level: 122
    thescreensavers's Avatar
    268
    Miami,FL
    464
    48 times
    Same thing here OP, since the Update " Better Droid X support" its been taking along time to load and its pretty laggy when scrolling.
    Hopefully an update will be coming soon
    Droid Does
  1. Running reeeeally slow...
    By hollywood in forum Droid X Help
    Last Post: 07-27-2010, 04:28 PM
  2. Undocking and home screen loading times
    By mbern1008 in forum Droid X Help
    Last Post: 07-27-2010, 08:15 AM
  3. advanced task killer, and apps loading in question...
    By NY_ROCKER in forum Droid X General Discussion
    Last Post: 07-20-2010, 02:54 PM
  4. Slow screen orientation change?
    By whitefiberz in forum Droid X General Discussion
    Last Post: 07-18-2010, 10:54 AM
  5. Slow data transfers
    By movadoevo8 in forum Droid X General Discussion
    Last Post: 07-15-2010, 08:59 PM
handcent black screen
handcent is slow
handcent loading slow
handcent running slow
handcent runs slow
handcent slow
handcent slow on droid
handcent slow to open
why is handcent slow
why is handcent so slow
