Need help with factory reset.
This is a discussion on Need help with factory reset. within the Droid X General Discussion forums, part of the Droid X Discussion category; Originally Posted by Integraoligist ok, how about this. Like Google Voice (which I seem to have problems with lately for some reason or another) If ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Like Tree3Likes
Thread: Need help with factory reset.
    Points: 45,915, Level: 100
    Posting Award
    macpro88's Avatar
    20491
    6,966
    322 times
    Quote Originally Posted by Integraoligist View Post
    ok, how about this. Like Google Voice (which I seem to have problems with lately for some reason or another) If I uninstall it, do a factory reset, it won't auto install... but then go install it from the market place, will it keep all of it's old settings or act like new?
    It will act like new, because you did a factory reset which wipes out all data from applications.
    DroidXForums Guidelines of Conduct
    Show Your Support and Become a Supporting Member Today!
    Points: 2,213, Level: 28
    Level completed: 43%, Points required for next Level: 87
    Overall activity: 0.7%
    Integraoligist's Avatar
    21766
    78
    great, thanks all for the help!
    Points: 5,583, Level: 48
    Level completed: 17%, Points required for next Level: 167
    Sefirosu's Avatar
    28086
    Boston, Ma
    611
    Maybe a stupid question here but I figured I'd ask. If you do a factory reset does it get rid of Z4root and unroot your phone?
    21766
    78
    Quote Originally Posted by mikeinrichmond View Post
    Here is my normal 'install new Rom' routine:
    Ok, I did a factory reset and when the above picture came up I kept swiping my finger around the screen like it shows... did that about 5 times then thought, hmm, this is not working... what if i tap each of the corners. YEP that worked. lol
    Anyway, yes, that skipped every setup. When it loaded completely i went to the phone and hit *228 and hit 1 to get the phone to actual work on VZ. I then turned on Wifi and downloaded each of the apps I wanted.
    Went back through all my settings then was good to go.
    Google Voice still seems to have issues for some reason. It my be the app and not the phone. 20% of the time when I try sending a text it will just sit there and try to send... it never does. And when it's acting like this, all incoming texts are locked out too.
    I have to either restart the phone, or goto Settings>Applications>Manage Applications>Google Voice>Force Stop. Then go restart the app.
    Ideas on what is going on?
    Posting Award
    macpro88's Avatar
    20491
    6,966
    322 times
    Quote Originally Posted by Sefirosu View Post
    Yes and no, it will get rid of z4root, so make sure have you the .apk on your SD card, and no, factory resets do NOT un-root your phone.
    You don't swipe, you "tap" each corner lol. Its ok, I did that my first time too. Glad you figured it out.
    And I do not use Google Voice, so I don't know, but it does sound like it might be a server error when trying to send and receive. I guess if the problem persists, search the help at Google Voice or send them an email from the address provided from the Market.
    Sefirosu's Avatar
    28086
    Boston, Ma
    611
    Ok so how do I go about going back to a brand new, out of the box phone? I installed Apex, I did my backup. Where do I go from here?
  1. Factory reset
    By Carpetman in forum Droid X General Discussion
    Last Post: 02-14-2011, 02:21 PM
  2. Factory Reset?
    By droidxer in forum Droid X Help
    Last Post: 12-29-2010, 08:42 PM
  3. How to to do factory-reset?
    By MDDC in forum Droid X Help
    Last Post: 11-12-2010, 02:49 PM
  4. factory reset
    By zero66 in forum Droid X Help
    Last Post: 10-04-2010, 12:17 PM
  5. Factory reset.
    By DolphinxManiax23 in forum Droid X Help
    Last Post: 09-19-2010, 07:26 AM
How To Backup Droid X
how do i reset motorola i474
how to reset i474 phone
how to restart a droid x like new
i474 unroot
i474-n hard reset
make droid x like factory new
master reset iphone i474
moto droid x hard reset from powe off
reset do motorola i474
