If I do a factory reset, do I need to format my sd card. I'm ready to just reset and then go to Darkside 4.2 on a fresh setup.
This is a discussion on Factory reset within the Droid X General Discussion forums, part of the Droid X Discussion category; If I do a factory reset, do I need to format my sd card. I'm ready to just reset and then go to Darkside 4.2 ...
Factory reset doesn't do much but wipe your user data. If you want a fresh install, just wipe data/cache in clockwork then install the ROM.
Those bootscreens just don't want to go away. I had the same issue with every ROM I have used. There is a zip file of the stock "M" bootscreen. I'm sure D-Xer will be posting it for you in a bit.
Also it doesn't hurt when in clockwork to format data and cache instead of just wiping. When in clockwork go to mounts and storage>format data and then format cache.
Load up liberty then to to toolbox. From there you can load up any number of boot animations. The stock m is there. Once you load up the stock m boot logo you can flash to another Rom and see them instead of liberty
Wooops, sorry just saw this. Here's the stock Moto logo carpetman. Just install it in clockwork, no need to wipe anything. http://db.tt/tYf26Qj
It seems that I got my problems solved ,thanks to the great people here on this site . And many thanks to CKMATE for the Fiero boot logo he made for me.
Need to SBF? Try this.
Root .602 & .605 info here.
DROOOID Notification Sound
Gingerbread Red "M" Boot Logo
Froyo White "M" Boot Logo
