Virtual Wifi - Laptop as Wifi Extender
This is a discussion on Virtual Wifi - Laptop as Wifi Extender within the Droid X General Discussion forums, part of the Droid X Discussion category; I don't know about anyone else, but my laptop gets a better wifi signal than my X. As my laptop is usually on, I set ...
Results 1 to 10 of 15
Like Tree4Likes
Thread: Virtual Wifi - Laptop as Wifi Extender
    Points: 17,929, Level: 85
    Snow02's Avatar
    22940
    3,769
    142 times
    I don't know about anyone else, but my laptop gets a better wifi signal than my X. As my laptop is usually on, I set it to use the virtual wifi feature in windows 7 to serve as a wireless repeater. This is good for another 150 feet or so of range, and I don't have to worry about my signal dropping.
    The commands for this can be found easy enough, but I put them into a a batch file you can run to start it and turn it off.
    You must have windows 7 and a compatible wifi adapter in your computer, but most any made in the last four or five years are probably fine.
    To use, just right click wlan_on and run as administrator. This will set up a hotspot with the name "Laptop" and a key of 1234567890. You can right click and edit the file to change the name or security key if you wish. To turn it off, just run wlan_off.
    Hopefully someone finds it useful.
    Attached Files Attached Files
    I have my laptop connected to my neighbors router via wireless. My xbox doesnt pick up the connection quite as well. Can this be used to bridge the two connections through my laptop? Ive tried, but most forums ive checked say i need a wired connection to my laptop. Is this true?
    Points: 11,775, Level: 71
    Level completed: 32%, Points required for next Level: 275
    mugz91's Avatar
    33258
    West Virginia
    2,304
    65 times
    Quote Originally Posted by crimsondethomen View Post
    Neighbor's router, huh? I assume this is with permission, right?
    Rescue Squad
    Points: 28,311, Level: 98
    Level completed: 97%, Points required for next Level: 39
    Leach19m's Avatar
    31277
    Washington
    7,053
    234 times
    lol who hasn't borrowed wifi without consent from their neighbor. When I first moved away from home I couldn't afford internet, but it was in an apartment and no one knew that they should protect their network, so I had free wifi for a while.......
    Ahem. What I meant to say is that stealing wifi is bad, mmkay
    Points: 2,402, Level: 29
    Level completed: 68%, Points required for next Level: 48
    Overall activity: 21.2%
    Brad92's Avatar
    46310
    Aug 2011
    Bleiblerville, TX
    754
    14 times
    You can use the laptop to connect to the network and an ethernet cable from the laptop to the Xbox.
    I did it using my phone as a wifi hotpot so I could update my 360.
    Random ROM'd X
    Snow02's Avatar
    22940
    3,769
    142 times
    You can use this to bridge the two. The only requirement is windows 7 and a wireless card that supports it. Most laptops that came with 7 or vista will.
    Points: 38, Level: 1
    Level completed: 76%, Points required for next Level: 12
    lmagee3276's Avatar
    49283
    Oct 2011
    Wifi Extender
    I downloaded your wifi extender. I see it but it says no internert access so when i try to use it on my Droid it just goes back to whatever wifi connection i alrady had.
    Quote Originally Posted by Snow02 View Post
    Snow02's Avatar
    22940
    3,769
    142 times
    You need to set your primary connection to share internet access with the virtual connection.
    mistergq79 likes this.
    how do i do that
    Points: 298, Level: 5
    Level completed: 96%, Points required for next Level: 2
    arbboy1998's Avatar
    58885
    May 2012
    Thanks-A-Million!
  1. wifi help
    By jbreezy in forum Droid X Help
    Last Post: 12-28-2010, 01:14 PM
  2. WiFi ID
    By Shiyan in forum Droid X Help
    Last Post: 12-15-2010, 10:36 AM
  3. Replies: 1
    Last Post: 10-26-2010, 05:31 PM
  4. 3g vs wifi
    By thursday in forum Droid X General Discussion
    Last Post: 09-09-2010, 09:25 AM
  5. Which WiFi do we have on the DX
    By bigdog9586 in forum Droid X General Discussion
    Last Post: 08-04-2010, 01:36 PM
how to use laptop as wifi repeater
how to use your laptop as a wifi extender
use laptop as wifi extender
using laptop as wifi extender
using laptop as wifi repeater
virtual wifi extender
virtual wifi.zip
wifi repeater laptop
