Can I charge via 12 volts?
This is a discussion on Can I charge via 12 volts? within the Droid X General Discussion forums, part of the Droid X Discussion category; So Motorola doesn't give any input power range specs I could find. Basically, I have a Garmin GPS in my car that I installed a ...
Thread: Can I charge via 12 volts?
    stevecaz's Avatar
    2853
    Basically, I have a Garmin GPS in my car that I installed a hardwired power port. It is a 3.5mm stereo mini plug, and I made a custom 3" long wire with the 3.5mm jack on one side and the Garmin mini-USB on the other.
    So anyway, this makes for a neat installation with a tiny port in the dash to plug in the garmin. I'd like do do the same for the Droid X car dock by making a new cable with the appropriate micro USB end. However, can I use direct 12v power into the Droid? So many devices now can take a huge power range, I'm just looking if anyone has those specs.
    Otherwise I suppose I could custom make a wire using the guts of a 12v power adapter that is stepping down to 5v in the middle, but that is less tidy.
    Thanks.
    Tagger Second Class7 days registered250 Experience PointsThree Friends100 Experience Points
    Martin030908's Avatar
    18
    1,089
    47 times
    requires 850mA
    5V
    Points: 1,531, Level: 22
    Level completed: 31%, Points required for next Level: 69
    1 year registered3 months registered31 days registered100 Experience Points7 days registered
    Liquidmantis's Avatar
    584
    30
    I certainly wouldn't put 12v into it. One option would be to make a 12v-5v zener diode based voltage converter. With some heatshrink and something like part of the body of a pen or marker for the housing you should be able to make a clean looking cable.
    12V to 5V DC converter using Zener diode and transistor : simple electronics
  1. how long should i charge my BATTERY?
    By axelaTDK in forum Droid X General Discussion
    Last Post: 08-15-2010, 02:05 PM
  2. why does verizon charge for visual voicemail when at&t does not?
    By silent1643 in forum Droid X General Discussion
    Last Post: 07-20-2010, 12:33 AM
  3. Replies: 0
    Last Post: 07-14-2010, 11:14 PM
how many amps does a garmin gps use
how many amps does a gps draw
how many volts does a gps use
how many volts does it take to charge a android
how many volts does the droid 3 take to charge
how many volts droid charger
how many volts should droid phones charge at
how many volts to charge an iphone
how many volts to charge an iphone 3?
how much power to charge a droid x
