I've used adw ex and launcher pro but I will have to say golauncher is def my favorite. Anyone else use it? If not i reccomend giving it a try.
This is a discussion on Go launcher within the Droid X General Discussion forums, part of the Droid X Discussion category; I've used adw ex and launcher pro but I will have to say golauncher is def my favorite. Anyone else use it? If not i ...
I tried it when it was first released...
What do you like about it that makes it better than LPP or ADW?
I have tried it..I keep going back to lpp for the widgets...if golauncher or zeam would provide integrated widgets for calandar and social networking id make the switch.
I've also never used launcher pro plus version might I add...how does it differ from the free version?
I'm using GO Launcher as well. I like the ability to add or delete screens with a click as well as change the home screen easily. The app drawer folder option is so convenient. I have had some issues after recent updates.
I really like GL it has a resize widget feature as well... you can also add a crap load of pages I currently have 8 but I had it up to 27 before I stopped adding.
