Display brightness
This is a discussion on Display brightness within the Droid X General Discussion forums, part of the Droid X Discussion category; Ok. So when I set my display screen to minimum. Why does it not stay at that seting. Or even on auto? Or any other ...
Results 1 to 8 of 8
Thread: Display brightness
    dropd1us's Avatar
    22273
    paducah, ky
    74
    Display brightness
    Ok. So when I set my display screen to minimum. Why does it not stay at that seting. Or even on auto? Or any other seting at that matter?
    sent from DROIDX =C3..(COMMAND COMMUNICATE CONTROL)
    dropd1us's Avatar
    22273
    paducah, ky
    74
    Anyone have this issue?
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    I do not... how are you initially setting it?
    Sent from my Droid X...
    Points: 1,784, Level: 24
    Level completed: 84%, Points required for next Level: 16
    dtsig's Avatar
    17218
    Oregon
    191
    7 times
    Not happening here. Just recently reduced it again and it is holding. Rooted but stock
    Points: 17,929, Level: 85
    Snow02's Avatar
    22940
    3,769
    142 times
    Are you confirming it's actually changing by checking the setting?
    Points: 649, Level: 12
    Level completed: 98%, Points required for next Level: 1
    evilashell's Avatar
    24931
    11
    I actually have that problem too. I keep my setting all the way down. But when I wake my x up the screen is brighter. In the settings its not lower but if I click on power magement widget till its at the lowest setting it is as dim as I originally set it. It is a noticable diffrence. I run unrooted and stock. Could it be an app changing the brightness and not lowering it when I close it?.
    dropd1us's Avatar
    22273
    paducah, ky
    74
    I try power control widget and go int settings. Both shows that its set to what I change it to and stays. But the brightness isn't where it should be at. If I reset it , it changes like it should. Does it all the time. Same issue I had with my droid 1 that I had before I upgraded to the x. Did it when I was stock before root to. I've always used screebl pro. But don't think that its causing it to happen. Ill try not using it for a couple of days and see. But seems like I tried that before.
    Points: 1,224, Level: 19
    Level completed: 24%, Points required for next Level: 76
    deno73's Avatar
    21540
    32
    I use an app called adjbrightness. Of course u have to be rooted. It works great.
  1. Camera Brightness
    By Mitsobar in forum Droid X Help
    Last Post: 03-20-2012, 09:37 PM
  2. Tasker will not set brightness below 20/255
    By lordrayvin in forum Droid X Apps
    Last Post: 12-03-2010, 01:39 PM
  3. The brightness issue
    By Westone in forum Droid X Help
    Last Post: 11-18-2010, 02:49 PM
  4. Screen Brightness
    By WhiteLabelDon in forum Droid X General Discussion
    Last Post: 09-09-2010, 06:06 AM
  5. automatic brightness
    By dadarkside in forum Droid X General Discussion
    Last Post: 07-30-2010, 08:52 PM
brightness on droid pro wont stay
display brightness droid x keeps changing
droid pro brightness wont stay on
droid pro screen brightness
droid x brightness keeps resetting
droid x display setting keep changing
how to keep brightness on droid pro
screen brightness not staying
setting brightness on droid pro
tasker atrix screen brightness
