Is there a way to save the pictures that you receive in text messages. I don't know why i can not figure it out. Thanks!!!
This is a discussion on Dumb Question!?!?! within the Droid X General Discussion forums, part of the Droid X Discussion category; Is there a way to save the pictures that you receive in text messages. I don't know why i can not figure it out. Thanks!!!...
Long press on it and it should give u the option to save.
Great...tested and the long hold worked. THANKS!!!! But, now I feel very DUMB!!!!!!!!!!!!!!!!
LOL... just remember, long press is your friend...
Sent from my DX
It took me a couple of days to get that one. I kept pressing the menu button thinking it had to be in there.
