FIRST STEP POST ROOT - Creating and Restoring Backups - Complete Guide
This is a discussion on FIRST STEP POST ROOT - Creating and Restoring Backups - Complete Guide within the Droid X General Discussion forums, part of the Droid X Discussion category; The first thing you should do after you root your phone (as in before doing anything else) is create a backup. This way you have ...
The first thing you should do after you root your phone (as in before doing anything else) is create a backup. This way you have somewhere to return to if you mess something up on your phone.
I read somewhere once that it's like having 999 lives in Contra. So true. So, I'm going to help you do it.
There are three tools you'll probably want. One is absolutely necessary, the other two are just handy to have.
Koush's Bootstrapper is a tool used to boot into clockworkmod recovery. You can make a custom image of your phone, install roms, etc. all from the recovery menu.
After downloading the .apk above, install it after browsing to the file on your sdcard.
In order to do so you must allow 3rd party sources to install apps. Turn this setting on in:
Make sure you're rooted, then load up "Droid X Bootstrapper". Press Bootstrap Recovery (it will prompt for superuser access and then say "success"), then Reboot Recovery (it will also ask for superuser access, then reboot your phone). Attachment 21068
Your phone will reboot into the clockworkmod recovery area - this is a crucial thing to get used to if you're going to play around with your phone.
Before you do anything else:
Use the volume buttons to navigate to "Backup and Restore"
Press the camera button to enter that menu
Select "Backup" and press the camera button
It will go through the backing up process, it may take a minute or two, don't battery pull or anything dumb like that.
When it's finished creating the backup it will kick you back to the main menu. Highlight "reboot system now" and press the camera button to reboot your phone.
Video Demonstration:
You now have a stable backup of your current system saved onto your sdcard. Anything you do - as long as you can get to clockwork recovery - is reversible back to this point.
To see how the backup feature functions you must first change something in your system: e.g. delete something off your home screen, a widget, anything. Do this now (make it noticeable to you - delete your clock or something).
Go back to Koush's Boostrapper app
Click Boostrap Recovery
Click Reboot Recovery
You're back in clockwork recovery again.
Navigate to "Backup and Restore"
Select "Restore" - this is where all your system flashes are kept, you should only have one.
Navigate to it, press the camera button. It will ask for confirmation
Select "Yes - Restore"
It will begin restoring your phone. It may take a minute. Once again do not do a battery pull. When it's finished you will be on the main menu. Select "reboot system now". It will boot you back into the operating system; however, now you're back to your flashed system file - you'll see the widget you had previously deleted returned to normal!
Reboot your phone. It will go right back into your regular interface - no clockwork recovery. The reason for this is in order to boot into the clockworkmod recovery the .apk checks for a minute file that basically tells the phone to redirect to the recovery - on a successful reboot with clockwork (if you have the .apk installed) it will delete this file so you don't boot back into clockwork unless you want to.
Backups are stored on the sdcard in /clockworkmod/backup - you can name them to anything you want in order to help you remember what backup they are (e.g. clean 2.2 or ssx)
pretty self explanitory, reboots your system back into the operating system
apply sdcard:update.zip
not very useful. applies update.zip from the root of your sdcard.
wipe data/factory reset
deletes all user data (apps, etc.)
wipe cache partition
wipes the cache of your phone
install zip from sdcard
selecting this and then "choose zip from sdcard" opens up a little browser. select any zip on your sdcard and it will install it. useful for romming, themeing, etc.
backup and restore
see above post
mounts and storage
careful in here. you can mount your sdcard which is handy, but don't format anything. I formatted /system once and bricked my DX
advanced
ignore this one
Also, to boot into clockworkmod recovery if you're bootlooping follow these instructions:
Plug usb into wall charger.
Plug phone into usb w/o the battery in the phone.
If it comes up with a battery with a ? in it, unplug and plug it back in.
If step 3 worked, you should be in Clockwork.
Rom Manager:
This is a handy tool. You can:
Name backups before they're created
Rename old backups
Restore backups
All from one menu! You do need the bootstrapper for this to work, however.
Titanium Backup:
This app backs up all your apps to your sdcard (and more!). This way if you have to .sbf, install a rom, or restore a backup you can reinstall all your apps quite easily.
Thanks for making/posting this. Easy to go through an explains alot. Thank you so much. One thing that happend to me is when i did the bootstrapRecovery an hit backup it ran an then finished but said error md5 or something...thoughts?or is normal
Edit....ran it two more times an now it went through...man i love this place
Reason: Dee da dee moment...
