What do i need to do? I have not received any over the air notification or anything![]()
This is a discussion on help! Havent gotten an update within the Droid X General Discussion forums, part of the Droid X Discussion category; What do i need to do? I have not received any over the air notification or anything...
Like no stuff in the notification bar?
Weavesworld.com
nope nothing. I'll check out that site later when i get some more time though thanks
My understanding is that they're still rolling it out in waves. I got mine after returning all the stock bloatware, changing the build properties to default and rebooting. Try restarting with wifi on and then check for updates.
Troubles installing OTA 2.3.340 Update? Click Here
All men by nature desire to know -Aristotle
New to Android? Click Here!
All-In-One POST ROOT Thread
Droid X Hacking Checklist
SBF without RSDlite
Go into Settings... Data Manager... Data Delivery... Social Applications and make sure Sync over WiFi Only is not checked...
Then go to Settings... About phone... System Updates.
For some reason, the updater is treated like a social app and if you have sync over wifi only enabled and are not on wifi, the updater wont find the update.
I never received anything in notification bar. I kept getting " no update available " until 12/12. But I had to reboot my phone. Don't know why but when I went back into settings after reboot ,update came right up.
