AHHHH MAN!!!!! I LOVED the fact that now all I had to do was PRESS answer instead of swipe it across the screen.
Damn update! It did nothing but "fix" whats not broken for me.
Is there anyway to get the answer button back I hate having to swipe it.
This is a discussion on No longer press to answer.... within the Droid X General Discussion forums, part of the Droid X Discussion category; AHHHH MAN!!!!! I LOVED the fact that now all I had to do was PRESS answer instead of swipe it across the screen. Damn update! ...
Umm I could never press to answer........![]()
Droid Does!!!
I still press to answer....lol
if phones unlocked you press to answer, if phones locked you slide to answer
yeah i think they need a press to answer its a little safer while driving. at least in my state where we can text and talk on the phone without bluetooth
Not true. If you have the pattern lock set, you just press answer or ignore. I forget what it was like before the update as I only had the phone for 3 days or so before the update. But as it is, I have answered phone calls in my pocket by accident, with the pattern lock set.
oooooooooooo I jus tested it out, you guys are right ( I never doubted you!) lol it makes sense too... why would I want to accident PRESS answer if i locked my screen hahaha DUH
Thanks!
On a similar topic, is there a way to turn off the vibration when unlocking?
Ok wait, you all are confusing me. Can you press to answer when phone is locked?
Droid Does!!!
