Will VZW replace my phone if there is a massive soft spot on my screen?
This is a discussion on Will VZW replace my phone if there is a massive soft spot on my screen? within the Droid X General Discussion forums, part of the Droid X Discussion category; The extended battery puts so much pressure on the display, and yes I use the cover that works with the battery haha. But I don't ...
Results 1 to 10 of 11
Thread: Will VZW replace my phone if there is a massive soft spot on my screen?
    hijackerjack's Avatar
    254
    49
    The extended battery puts so much pressure on the display, and yes I use the cover that works with the battery haha. But I don't have a warranty but I feel like my phone's LCD is gonna snap because of all the pressure and I wouldnt be surprised if it did. But if I show them, would I have a chance of maybe a replacement? (Even for a phone of lesser value)
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    Possibly - your best bet is to just stop by the store and ask. They will no more than say "nope" but I bet they will help you resolve it...
    254
    49
    Alrightt. Sounds good! Might as well go down there right now..
    20,509
    885 times
    Good luck and keep us posted!!
    Points: 82,727, Level: 100
    250 Experience PointsYour first Group31 days registered100 Experience Points7 days registered
    wicked's Avatar
    15645
    San Jose CA.
    5,245
    728 times
    The door that comes with the ext battery is suppose to fit just right and thus should have no ill effects on the phone.
    Just like having a reg. battery with the reg door. I've only heard people that use the reg door with the ext battery have this issue.
    If you did infact use the ext. battery door that came with with the ext. battery then any damage to your phone shiould be covered then right?
    Did you purchase the ext. battery and door from VZW? I've never had problems with getting replacements in the past from big red.
    Just take it in and see what they say
    254
    49
    Quote Originally Posted by wicked408 View Post
    I've been using the one that came with the extended battery. The door also oddly seems to be very loose and moves around a lot. Yeah, I bought he battery/door from VZW. Seeing your luck, I really hope I can get some sort of replacement, even if its a different phone... You can see the pressure that's put on the screen if you try to take off the battery cover. That pressure seems to always be there for me, never disappears. Thanks for the help!
    wicked's Avatar
    15645
    San Jose CA.
    5,245
    728 times
    no problem, but I wouldnt settle for a lesser phone. Don't mention that either. They'll most likely give you a replacement DX
    Points: 1,752, Level: 24
    Overall activity: 0.6%
    tech_head's Avatar
    4983
    Sillicon Valley, Ca
    257
    Quote Originally Posted by hijackerjack View Post
    But I don't have a warranty but I feel like my phone's LCD is gonna snap because of all the pressure and I wouldnt be surprised if it did. (Even for a phone of lesser value)
    How can you not have a warranty on a DroidX?
    It comes with a 1 year warranty....
    ArthurIhde's Avatar
    15367
    169
    yeah, should have the warranty, anyway, you could still see what they say
    Just bought a droid X
    Points: 2,618, Level: 31
    Level completed: 12%, Points required for next Level: 132
    jab1472's Avatar
    4031
    132
    Wow thanks guys for talking about this now I figured out why I keep getting a discolor in my screen I thought I had a weak spot but it was my hard case with my extended battery pushing on the back of the screen what are some of the holsters you guys sure using with the extended batteries
    Sent from my DROIDX
  1. Anyone have a soft spot on their screen???
    Last Post: 07-12-2012, 02:45 PM
  2. Weak spot in screen
    By jab1472 in forum Droid X Help
    Last Post: 11-22-2010, 11:06 PM
  3. Replies: 0
    Last Post: 11-08-2010, 09:29 AM
  4. 3G Hot Spot w/ Mac Issues
    By deejay520 in forum Droid X Help
    Last Post: 09-06-2010, 12:04 PM
  5. DROID X - 3G Wi-Fi Hot spot
    Last Post: 07-15-2010, 02:01 AM
droid x lcd spot
droid x pressure damage
droid x screen pressure
droid x soft spot
droid x spot on screen
how to replace screen on droid x
pressure dots on droid x
pressure point on droid x
soft spot on phone
spot on droid x screen
