How to Eliminate Duplicate Contacts
This is a discussion on How to Eliminate Duplicate Contacts within the Droid X General Discussion forums, part of the Droid X Discussion category; For whatever reason I have duplicate and even triplicate entries in Contacts. I suspect it has to do with an error in how I originally ...
Results 1 to 8 of 8
  • 1 Post By calpalmer
Thread: How to Eliminate Duplicate Contacts
    Points: 2,163, Level: 28
    Level completed: 9%, Points required for next Level: 137
    calpalmer's Avatar
    7463
    15
    For whatever reason I have duplicate and even triplicate entries in Contacts. I suspect it has to do with an error in how I originally set up to sync with Outlook. I would like to wipe out the phone-resident contacts file and start over. I can't see how to do that. Any help is appreciated.
    Cal
    boost192's Avatar
    8437
    95
    All your contacts get stored in your google account so they probably linked your outlook and google accounts go in to your google account online and delete the contacts that are duplicated.
    calpalmer's Avatar
    7463
    15
    This is what I've done.... I went into "Manage Applications" and selected the Contacts Storage and Contacts apps.... then I cleared the data and rebooted the Droid. Voila, the only contacts that remained were the Verizon ones (e.g., #BAL, #MIN, Voice Mail, etc.). I then resync'd using Missing Sync for Android (MarkSpace; it's in the Market), and now finally I just have one listing for each contact. I've unchecked the "Sync Contacts" box for each of the social media accounts (e.g., Facebook). Hopefully that takes care of it.
    The good thing about Missing Sync is it doesn't go through Google gmail/contacts -- goes direct to Outlook's address book.
    Cal
    SaulD likes this.
    boost192's Avatar
    8437
    95
    Nice thanks for the info
    ChrisSmithWebGuy's Avatar
    25895
    Seattle, WA
    I have the same problem in the past, no possible way but to delete those duplicates manually and it took me too long till I found a useful tool, the so called Scrubly Duplicate Contacts Remover..This tool really works well for me. You can also use this tool for you to get rid of frustrating duplication. just give it a try. hope this helps. Thanks.
    Points: 3,480, Level: 36
    Level completed: 87%, Points required for next Level: 20
    Getsome122's Avatar
    23496
    Bristol, TN
    912
    23 times
    make sure you arent removing ones where added info may have just caused it to put them in there twice and you may want to link them together. the facebook app caused alot of this for me and had to do alot of linking cause two or three of the same name were the same person but one contained email and facebook data and the other contained their phone numbers cause they were a contact in my phone before the fb app added them. so it may all seem doubled or tripled but it may just be added info for the same person because it came from different sources and they just need to be linked
    Wink duplicate contacts
    So how do you link them?
    Thanks!
    Themer
    Points: 15,649, Level: 80
    jeems's Avatar
    40702
    4,389
    176 times
    holy thread resurrection batman
    I think you go into edit contact and hit the menu button. There should be an option to link or join contact. When you press that it should let you choose the other contact to link it with. HTH and welcome to the forum!
    Check out my themes:
  1. Handcent Duplicate SMS Messages
    By s0n- in forum Droid X Hacks
    Last Post: 01-20-2012, 09:54 PM
  2. Clean install of Froyo helps eliminate problems
    By iresq in forum Froyo 2.2, News-Rumors-Wishes
    Last Post: 02-16-2011, 12:21 PM
  3. Help with duplicate friends
    By nymyth in forum Droid X Help
    Last Post: 08-28-2010, 04:12 AM
  4. Duplicate messages.....
    By Guam_Guy in forum Droid X Help
    Last Post: 07-28-2010, 05:48 PM
android duplicate contacts problem
delete duplicate contacts droid incredible
deleting duplicate contacts on droid
how do i delete duplicate contacts from droid x
how to delete duplicate contacts on droid
merge duplicate contacts moto x
missing sync android duplicate contacts
moto x duplicate contacts
motorola droid double contacts
