battery always read by 10%?
This is a discussion on battery always read by 10%? within the Droid X General Discussion forums, part of the Droid X Discussion category; In ROM discussions people keep saying how the battery is only reading by 10% at a time but I am confused because ever sinceI've had ...
Results 1 to 9 of 9
Thread: battery always read by 10%?
    JavaLlamaFTW's Avatar
    2649
    52
    In ROM discussions people keep saying how the battery is only reading by 10% at a time but I am confused because ever sinceI've had my X from 1 it has done that. Is every one elses like this or am I the only one?
    X Pursuant Achievements:
    Jaxidian's Avatar
    47
    Indianapolis
    694
    49 times
    Yup, 10% intervals is the best you'll get.
    2649
    52
    Makes me jealous of my friend with an evo, cause I have to think how long that I've been at that percent so I could be in the high 30s and not need to charge for a while or be in low 30s where I need to charge soon
    Points: 1,547, Level: 22
    Level completed: 47%, Points required for next Level: 53
    Overall activity: 0.0%
    mbern1008's Avatar
    1377
    122
    Yep until you get down to 15%
    2649
    52
    Is it somthing that can be changed software side or is that just the way the battery measures its self
    Points: 6,551, Level: 53
    Level completed: 1%, Points required for next Level: 199
    B360155's Avatar
    217
    North Richland Hills, TX
    389
    32 times
    The Battery Left app provides information in increments of 1%. However, I'm not sure that the way it calculates the percentage and time left on the battery is all that accurate. I believe this is how it works. After you first install the app, you calibrate your battery by running it through an entire cycle until it's completely drained. Whatever that time is becomes 100%. Then it calculates percentage left in the future as a percentage of that 100% time figure. That will work if you use your phone in the same manner every day, but if you depart substantially from your "normal" usage on any given day (either more or less than average use), it could be off by quite a bit.
    jmiller148's Avatar
    3461
    72
    Actually if you are stock the battery notification icon goes from 0,10,20,40,60,80 and 100. The system still reads in increments of 10 until you get to 15. At that point it will read every 5 till 0. You can decompile framework and edit the xml so the notification bar will reflect the 10% and 5% readings.
    Wait... let me test the 1% readings again to confirm this. The charging xml uses values like 29 so it seems it could read down to 1%.
    EDIT: It appears I am correct. This might be able to be changed at a lower level which at this point is beyond my scope.
    2649
    52
    Well its good to know that someday i will actually be able to tell what % i am actually at, thanks for looking into it
    Jaxidian's Avatar
    47
    Indianapolis
    694
    49 times
    Quote Originally Posted by JavaLlamaFTW View Post
    Don't be jealous. In fact, use his battery meter to measure yours. When he hits 30%, you should be ~60%. :-P
  1. Where to read up on rooting?
    By Corpsman in forum Droid X General Discussion
    Last Post: 10-16-2010, 08:10 PM
  2. Mark as read?
    By marmer in forum Droid X Help
    Last Post: 10-12-2010, 03:51 PM
  3. computer can't read usb cord
    By alazykorean in forum Droid X Help
    Last Post: 09-09-2010, 08:19 PM
  4. Everyone please read... My new app is coming!
    By NY_ROCKER in forum Droid X Apps
    Last Post: 08-23-2010, 06:05 PM
  5. [READ ME] What to post here!!!
    By JimMariner in forum Pending Submissions / Questions
    Last Post: 07-18-2010, 04:30 PM
droid razr charging by 10%
