How To : Droid X Screenshots
This is a discussion on How To : Droid X Screenshots within the Droid X FAQs forums, part of the Droid X Discussion category; This simple walk though will show you how to do a screenshot capture on your Motorola Droid device. In fact, this will work on most ...
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 65
Like Tree9Likes
Thread: How To : Droid X Screenshots
    Points: 123,642, Level: 100
    Overall activity: 92.9%
    Garemlin's Avatar
    15
    Delaware
    3,846
    358 times
    This simple walk though will show you how to do a screenshot capture on your Motorola Droid device. In fact, this will work on most Google Android device. Unfortunately there is a simple program that I am aware of you can install on your Motorola Droid device and do a simple screen capture. At least not yet.
    Please note that when you plugged your X into your PC for the first time it should have installed the drivers so the USB driver install may not be necessary. This is a step by step for the original Droid which did not automatically install the drivers. I am using this procedure for my X so it works fine.
    What You Need:
    • When you first connect the Motorola Droid, windows will prompt for you to install a driver. If you don't see that prompt, go to your control panel -> system -> Hardware Devices. Find the one with the "?" icon and point the driver update to where you extract the droid_usb_driver to (this will work on other Android devices
    • On your Motorola Droid, go to settings -> application -> development and check "USB Debugging" (ref pics 1,2,3 below)
    • Extract the Android SDK
    • Extract and install Java SE Development Kit
    • Go to the Android SDK folder and go to sub folder "tools" (ref pic 4 below)
    • Launch "ddms.bat" (ref pic 5 below)
    • To start screen capture, go to "Device" and "Capture Screen" (ref pic 6 below)
    Below is what you get. That is a shot of my current X home screen. Have fun and be sure to post your results in this thread. http://www.droidxforums.com/forum/dr....html#post7190
    And here are a few screen caps of the step by step courtesy of DX member thescreensavers.
    1.
    2.
    3.
    4.
    5.
    6.
    Source: Mobile Technology Deals and Help
    Points: 7,208, Level: 56
    500 Experience Points250 Experience PointsCreated Album picturesThree Friends100 Experience Points
    didiwags's Avatar
    55
    Minnesota
    1,450
    21 times
    hahah nice!! I will do this when I get home, going to a movie with my SIL!!!
    Droid Does!!!
    silent1643's Avatar
    606
    67
    damn they really need an app to take the screen shot, auto upload it to image shack, and then give you the link..
    had one on my jb iphone that did this was - great
    500 Experience Points7 days registered250 Experience PointsCreated Album pictures100 Experience Points
    HiFlow5 0's Avatar
    725
    East Longmeadow,MA
    59
    What icon pack are you using?
    Garemlin's Avatar
    15
    Delaware
    3,846
    358 times
    Quote Originally Posted by HiFlow5 0 View Post
    Listed in the first post. They are my custom icons.
    ajs2294 likes this.
    Points: 1,841, Level: 25
    Level completed: 41%, Points required for next Level: 59
    gardobus's Avatar
    42
    Tucson, AZ
    234
    10 times
    There ARE apps to do this but they require root. Once we get root, look for ShootMe or Drocap2 in the market. They both work great.
    Droid X - Eris - Droid - Storm1 - Curve 8330 - Lots of LG Dumbphones
    HiFlow5 0's Avatar
    725
    East Longmeadow,MA
    59
    Quote Originally Posted by Garemlin View Post
    I see it now, did not see your sig originally on tapa talk. Jumping on the PC now to download zip. Great job BTW.
    Garemlin's Avatar
    15
    Delaware
    3,846
    358 times
    Quote Originally Posted by gardobus View Post
    Yes I know this. But I didn't want to even bring that up and add confusion. We are not there yet.
    gardobus's Avatar
    42
    Tucson, AZ
    234
    10 times
    I figured you knew, I was just saying it since someone said that there should be apps for this. Don't want them thinking that no one has thought of it. It just isn't possible w/o root.
    unknowndroid's Avatar
    947
    76
    18 times
    On my Droid, I used DxTop home replacement and it did screen caps without root. Haven't bothered to install on Droid X, 7 screens are plenty :-)
  1. Screenshots of your Droid X home screens
    By Garemlin in forum Droid X Themes
    Last Post: 12-01-2014, 06:07 AM
Droid x screenshot
droid x screen shot
how do you screenshot on a droid x
how to screenshot droid x
how to screenshot on a droid x
how to screenshot on a motorola droid x
how to screenshot on droid x
motorola droid x screenshots
screenshot droid x
