Damn... SDK.. Root.. Java... Wouldn't it be easier to just like hold your Droid up and take a picture of the screen with an iPhone?
I say this partly in jest, but also as an owner of both a Droid X and an iPhone 4. Guys... It should be as easy as it is on an iPhone to take a screenshot on the Droid / Android. Hold two buttons down at the same time. None of this root, java, sdk business. You want wide adoption of Android? Make it THAT easy.
9Likes
if you want to try the
