Wifi on/off?
This is a discussion on Wifi on/off? within the Droid X FAQs forums, part of the Droid X Discussion category; When I use the little Wifi on off widget I can never reconnect to my wifi instantly. Is there anyway to instantly connect to saved ...
Results 1 to 7 of 7
Thread: Wifi on/off?
    ajs2294's Avatar
    9104
    5
    Wifi on/off?
    When I use the little Wifi on off widget I can never reconnect to my wifi instantly. Is there anyway to instantly connect to saved networks?
    Also, does anyone know how to prevent the phone from skipping to mobile websites all the time?
    Sorry for the newbie questions just go my X today
    Points: 1,993, Level: 26
    Level completed: 93%, Points required for next Level: 7
    izomiac's Avatar
    1430
    26
    Wifi takes some time to reestablish a connection. For example, with WPA2 there's a four-way crypto handshake that takes a few seconds, plus some signature verification that might take a while. It'd be nice to instantly reconnect, but routers won't let you do that. What they will allow is if you stay connected the phone can enter a powersaving mode where there's hardly any activity, but it can nearly instantly convert it to a full connection if you send or receive anything.
    To use this keep wifi on, and configure Android to never turn it off. Don't do this unless you are within range of a saved wifi network all the time, since otherwise it'll kill your battery searching for networks. Speaking of which, a rooted user can modify build.prop to configure how often Android searches for networks. The default is 60 seconds, so reducing it will use more power but discover new networks more quickly, and increasing it will save power but it won't scan for networks as often.
    As for mobile websites, change your user agent to a "Desktop" browser. It's buried in Settings somewhere, and you might have to go to "about:settings" or something to get to the right menu. Sorry for being vague on the details, but it depends on which browser you're using, and this should give you enough information to google some step-by-step instructions.
    Points: 3,897, Level: 39
    Level completed: 65%, Points required for next Level: 53
    500 Experience Points250 Experience Points31 days registered7 days registered100 Experience Points
    Xzombie69X's Avatar
    5584
    179
    I also have this problem, I did notice when i bring up the wireless networks in range then it will like instantly connect to my saved network.
    Stock Droid X2
    Points: 944, Level: 16
    Level completed: 44%, Points required for next Level: 56
    Overall activity: 0.0%
    chuck6961's Avatar
    6483
    32
    i can connect to my home network as soon as i turn on wifi but i did notice it does take a few seconds to establish a connection
    Agent X Achievements:
    Asharad's Avatar
    294
    Tiamat
    1,100
    25 times
    it takes a few seconds to connect... maybe 10-15. It works well enough.
    izomiac's Avatar
    1430
    26
    Hmm, thinking a little more, there should be a few ways to minimize the time it takes to connect. First, only turn on wifi when you're in range, otherwise the initial scan won't find anything and your phone won't scan again for another minute. Second, disable WEP/WPA (bad idea for other reasons, but connections will be faster, the gist of this idea is to move down to the lowest security that you're comfortable with). Third, use a static IP address so you can avoid DHCP.
    Points: 3,189, Level: 34
    Level completed: 93%, Points required for next Level: 11
    Uncle Chan's Avatar
    1027
    150
    Quote Originally Posted by Asharad View Post
    Same here. But it takes that long for my laptop to connect. So, no big deal.
  1. Can't turn off WIFI!
    By Lumberg in forum Droid X General Discussion
    Last Post: 09-23-2010, 08:30 PM
  2. 3g vs wifi
    By thursday in forum Droid X General Discussion
    Last Post: 09-09-2010, 08:25 AM
  3. WiFi only mode?
    By bchampnd in forum Droid X General Discussion
    Last Post: 08-11-2010, 11:16 AM
  4. Wireless G WiFi
    By bigdog9586 in forum Droid X General Discussion
    Last Post: 08-08-2010, 12:21 AM
  5. Which WiFi do we have on the DX
    Last Post: 08-04-2010, 12:36 PM
droid 3 wifi turning off
droid x wifi keeps turning off
droid x2 wont connect to wifi
droid x3 wont connect to wifi
why does my droid wifi keep cycling off and on
why does my droid x turn on wifi
why does my droid x wifi turn on and off
why does my motorola droid keep turning wifi off
wifi keeps turn off and on droid x
wifi keeps turning off android
