How To: Setup ADB on Windows 7 64bit (Should also work on 32bit)
This is a discussion on How To: Setup ADB on Windows 7 64bit (Should also work on 32bit) within the Droid X FAQs forums, part of the Droid X Discussion category; This is a copy/paste from the thread I made over at AllDroid. Figured some people here might find it useful as well. Ok, so after ...
Results 1 to 9 of 9
  • 1 Post By hacku
Thread: How To: Setup ADB on Windows 7 64bit (Should also work on 32bit)
    hacku's Avatar
    2905
    11
    Ok, so after seeing how much trouble most people have with Windows 7 I decided to make this. I too found the previous instructions a little confusing, but I finally figured out what I was doing wrong and was able to install them. Trust me, that when I point out what you guys were doing wrong you're going to laugh too...lol
    1. Download the attached .ZIP file and extract it somewhere you can find it (ie: C:\ADBDrivers_v3)
    2. Make sure your phone has USB Debugging enabled (Menu>Settings>Applications>Development)
    3. Plug USB cable into phone and put in USB Mass Storage Mode
    4. Open up Device Manager (Located in Control Panel\All Control Panel Items)
    5. Under Other Devices you should now see Motorola ADB Interface (Windows could not install the drivers for me)
    6. Right-click and select Update Driver Software
    7. Click on Browse my computer for driver software
    8. Click on Let me pick from a list of device drivers on my computer
    9. Now this is the step where I'm sure most of you messed up on. Click on Show All Devices then Next. DO NOT CLICK ON ADB INTERFACE FROM THE LIST!
    10. Click on Have Disk button
    11. Click Browse button
    12. Go to C:\ADBDrivers_v3\usb_driver\ then select android_winusb.inf and click the Open button
    13. Click OK
    14. Select Android Composite ADB Interface and click the Next button
    15. Click Yes on the Update Driver Warning window
    It should take a few seconds to install the driver. You'll get a window saying that you driver was successfully updated (click the Close button), and your phone should now show up at the top of the device list under Android Phone.
    ENJOY!!!
    vfrei likes this.
    Points: 1,038, Level: 17
    Level completed: 38%, Points required for next Level: 62
    ColdSteele's Avatar
    8533
    31
    can you link to the original post at alldroid so i can get the zip file- i cant find it
    nevermind, i got it
    Points: 39,537, Level: 100
    psychotic_penguin's Avatar
    5117
    Rapid City, SD
    5,091
    243 times
    Confirmed working on 32 bit
    Section8's Avatar
    22793
    The new Motorola Drivers 5.0.0 finally fixed this horribly annoying problem!!
    Points: 58, Level: 1
    Level completed: 16%, Points required for next Level: 42
    Overall activity: 1.4%
    Ecko7XP's Avatar
    60564
    Jul 2012
    8
    this is not working all does shows up is ADB interface- Mot Composite ADB interface please help me to get this fixed
    Points: 15,991, Level: 81
    Level completed: 29%, Points required for next Level: 359
    Overall activity: 76.3%
    BHuber09's Avatar
    34670
    Atlantis
    5,553
    137 times
    What all have you done so far?
    Download these. Its adb and all you have to do is type in cmd.exe (path) adb
    http://db.tt/HGgIxjBu
    http://db.tt/PuSqYCJd
    http://db.tt/OySOGg0j
    FreeMyMoto!!!
    If you need help PM me!!!
    Ecko7XP's Avatar
    60564
    Jul 2012
    8
    were do i put these files at?
    BHuber09's Avatar
    34670
    Atlantis
    5,553
    137 times
    You put them where ever you want. I keep mine on c:/theme/ but you can keep them wherever you just have to have them all 3 in the same location
    FreeMyMoto!!!
  1. Flashing the .604 SBF With Windows 7
    By PJ. in forum Droid X Hacks
    Last Post: 03-19-2012, 07:41 PM
  2. custom dock setup...possible?
    By Phildo in forum Droid X General Discussion
    Last Post: 08-31-2010, 09:16 PM
  3. Complicated setup form BB to DroidX
    By Cigar_Junkie in forum Droid X Help
    Last Post: 08-31-2010, 07:41 PM
  4. ADB DRIVERS - WIN7 64bit
    By dancellabz in forum Droid X Help
    Last Post: 08-26-2010, 12:27 AM
  5. Private WIFI Setup Issues - Device Name
    By hannja in forum Droid X Help
    Last Post: 07-23-2010, 03:50 PM
adb droid x
droid x adb
droid x adb driver windows 7
motorola adb driver
motorola adb interface
motorola adb interface download
motorola adb interface driver
motorola adb interface driver download
motorola adb interface driver windows 7
motorola adb interface windows 7
