To by pass activation on the Motorola Droid X:
Press the 4 corners of the screen in a clock wise direction starting with the top left corner. Your device should then jump straight to the home screen!
This is a discussion on Bypass Android Activation Screen on Motorola Droid X within the Droid X FAQs forums, part of the Droid X Discussion category; To by pass activation on the Motorola Droid X: Press the 4 corners of the screen in a clock wise direction starting with the top ...
After doing this to skip activation, how do you go back and activate it?
Darn I needed this a few weeks ago when i got my phone. I couldn't activate it for 8 hrs and I wanted to bypass that screen to check out the phoneOh well glad to know there was a way.
Does this hold true for other phones?
If you bypass the activation screen can you use wifi?
Yep
You can't use the market without signing in, so keep z4 and bootstrap apk's on your sd card to install them. This way if you sbf back to froyo to either upgrade to gb, or to load a different rom, you can do it much quicker by not having to wait for google to sync.
