Bypass Android Activation Screen on Motorola Droid X
This is a discussion on Bypass Android Activation Screen on Motorola Droid X within the Droid X FAQs forums, part of the Droid X Discussion category; Yes, you can use it as a wifi only device, and download from the playstore. Bypass the activation, go into settings and put it in ...
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Like Tree8Likes
Thread: Bypass Android Activation Screen on Motorola Droid X
  1. #21
    Points: 67,578, Level: 100
    Overall activity: 16.2%
    HarleyDude's Avatar
    19213
    Philly area
    8,191
    460 times
    Yes, you can use it as a wifi only device, and download from the playstore. Bypass the activation, go into settings and put it in airplane mode, then turn wifi back on.
  3. #22
    Points: 1,210, Level: 19
    Level completed: 10%, Points required for next Level: 90
    Overall activity: 5.8%
    runeraze's Avatar
    67643
    Dec 2013
    Quote Originally Posted by HarleyDude View Post
    Thank you for a quick reply. Will there be a different bypass for the Milestone Droid X2 MB867 or will it be bypassed exactly the same? Also is there any notable differences in generally anything between milestone and version?
  4. #23
    Points: 18,395, Level: 86
    Level completed: 9%, Points required for next Level: 455
    Overall activity: 99.7%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    287 times
    4 corners bypass should work, also can try the Boot Android {No BP} method
    shown here
    by Tomsgt123
  5. #24
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    287 times
    Quote Originally Posted by runeraze View Post
    ... Also is there any notable differences in generally anything between milestone and version?
    Verizon?
    not a lot of difference, the Droids are made for verizon and have more bloatware (unneeded apps).
    hardware is the same, milestones are flashed for non verizon networks, and will not work on Verizon and vice versa.
    edit: If you plan on flashing roms, be sure to follow the MX2 directions and files
  6. #25
    four corners swipe message not working
    I have tried for hours to bypass the droid x activation screen but to no avail. I've not found another way either. Help please.
  7. #26
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    287 times
    Quote Originally Posted by mgnmorphis View Post
    which model is listed on label under battery.
  8. #27
    model number motmb 810bat
  9. #28
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    287 times
  1. Best screen protector for Droid X?
    By Scuba Steve in forum Droid X Accessories
    Last Post: 05-22-2011, 08:21 AM
  2. Activation fees waived?
    By silv3rskeeter in forum Droid X General Discussion
    Last Post: 07-29-2010, 05:26 PM
  3. Steinheil screen protectors available now!!!
    By Garemlin in forum Droid X Accessories
    Last Post: 07-17-2010, 05:39 PM
  4. DROID X - Change the Screen Orientation
    Last Post: 07-15-2010, 03:28 AM
  5. Screen Protector?
    Last Post: 07-14-2010, 09:09 PM
bh5x dialer codes
bypass activation droid x
bypass android activation screen
bypass droid x activation
droid x activation bypass
droid x bypass activation
droid x factory reset skip activation
droid x skip activation
how to bypass droid x activation screen
motorola bypass activation
