Crazy night of SBFing
This is a discussion on Crazy night of SBFing within the Droid X FAQs forums, part of the Droid X Discussion category; Had a night to remember, I was on Liberty 3 and wanted to SBF to do a clean install of Apex, SBF went flawless, Root ...
Thread: Crazy night of SBFing
    Points: 13,902, Level: 76
    Level completed: 63%, Points required for next Level: 148
    Overall activity: 78.9%
    DroidXFanatic's Avatar
    52093
    Nov 2011
    1,104
    42 times
    Had a night to remember, I was on Liberty 3 and wanted to SBF to do a clean install of Apex, SBF went flawless, Root went flawless but when using Droid2 bootstrap to install every single time I got a installation abort, "bad". I tried about 10 times and with different roms and same result the zipp file could not be installed but what is weird is that wugs tether patch would install just not any rom. This has never happened to me on Gingerbread. I finally gave up last night and SBF to froyo this morning, rooted, installed droidx bootstrap, installed .15 radio and successfuly installed darkslide on first try. I have no idea why I couldn't install a rom on GB. Any ideas what could have been the issue? Also does anyone know if the TBH 3g hotspot hack is similar to Wugs Tether patch where I can use any wireless tether app of my choice just not the 3g Verizon one? Does this patch also remove data tracking? Thanks in advanced for the help.....
    Sent from my DROIDX
    Points: 22,755, Level: 93
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    Quote Originally Posted by DroidXFanatic View Post
    Sent from my DROIDX
    I'm not sure as to why all your zips where bad.. that's very odd.
    But yes the TBH tether hack is basically the same thing the only difference is that it doesn't install the app. I think that's what I remember
    FreeMyMoto!!!
    FreeMyMoto!!!
    If you need help PM me!!!
    52093
    Nov 2011
    1,104
    42 times
    Quote Originally Posted by BHuber09 View Post
    FreeMyMoto!!!
    Yeah it's very strange because I have installed those same exact zips in the past without a problem unless somehow they got corrupted during transfering but I doubt it. I kinda don't wanna go through all that again at least not anytime soon so ill ride my luck on Froyo for a bit haha thanks man!
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    Yeah they. l couldn't have been corrupted haha I mean half your zips work and the other half does? Yeah that one is over my head.
    FreeMyMoto!!!
    FreeMyMoto!!!
  1. Sbfing to 340 help
    By usiris208 in forum Droid X Hacks
    Last Post: 08-12-2011, 10:17 AM
  2. question on sbfing ?
    By kevmex1989 in forum Gingerbread Development and Hacking
    Last Post: 06-29-2011, 06:15 AM
  3. sbfing
    By djack93 in forum Hacking Help
    Last Post: 05-22-2011, 02:24 PM
  4. First time SBFing
    By goblueboy in forum Droid X Help
    Last Post: 04-22-2011, 05:48 PM
  5. Question about SBFing
    By ryanh6447 in forum Droid X Hacks
    Last Post: 01-01-2011, 08:04 PM
droid x sbfing
help with sbfing a droid x
sbfing my droid x
tether patch verizon iphone
what is sbfing
