Unetbootin prompt keeps showing up on reboot
This is a discussion on Unetbootin prompt keeps showing up on reboot within the Droid X FAQs forums, part of the Droid X Discussion category; I used wugfresh method to sbf I deleted the program but every time I start my computer it gives me a choice windows 7 or ...
Results 1 to 1 of 1
Thread: Unetbootin prompt keeps showing up on reboot
    Points: 1,202, Level: 19
    Level completed: 2%, Points required for next Level: 98
    phatreno's Avatar
    45560
    Aug 2011
    65
    I used wugfresh method to sbf I deleted the program but every time I start my computer it gives me a choice windows 7 or unetbootin, I deleted every thing todo with the sbf removed from control panel nothing helps tried reinstalling wugfresh sbf when I reboot computer 2 unetbootins show I can delete one no problem but can't get rid of first one if I chose it iget a error.does any one now how to delete thru boot manager
  1. Replies: 7
    Last Post: 01-02-2012, 06:31 PM
  2. Superuser Prompt
    By dljdx in forum Hacking Help
    Last Post: 04-11-2011, 11:51 PM
  3. Command Prompt
    By w00tn3ss in forum Froyo 2.2, News-Rumors-Wishes
    Last Post: 02-24-2011, 10:12 AM
  4. caller ID app prompt after call
    By haknslash in forum Droid X General Discussion
    Last Post: 09-25-2010, 08:25 PM
  5. RSDLite 4.7 and my CMD prompt
    By btucker2003 in forum Droid X Help
    Last Post: 08-31-2010, 11:26 PM
how to remove unetbootin from windows boot manager
remove unetbootin boot
unetbootin after reboot
unetbootin boot prompt
unetbootin default
unetbootin default screen
unetbootin keeps restarting
unetbootin only shows default
unetbootin showing default only
what to do after unetbootin screen
