Questions on flashing roms and sbfs
This is a discussion on Questions on flashing roms and sbfs within the Droid X FAQs forums, part of the Droid X Discussion category; Hello. I have a Milestone X (Droid X). I have rooted it, backed up apps/settings with tibu, created a nandroid backup, and am now interested ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: Questions on flashing roms and sbfs
    Points: 651, Level: 13
    Level completed: 2%, Points required for next Level: 49
    Overall activity: 1.7%
    wvcadle's Avatar
    53286
    Dec 2011
    86
    Hello. I have a Milestone X (Droid X). I have rooted it, backed up apps/settings with tibu, created a nandroid backup, and am now interested in flashing a custom rom.
    Questions follow:
    1. Is there a difference between roms and sbfs?
    2. After installing a custom rom, will all of my applications work?
    3. Are custom roms carrier specific (made for Verizon, etc.)?
    4. If 3 is true, are there any roms safe to flash to a Milestone X with nTelos?
    5. To go back to 'out of the box' settings, is all I have to do is flash a proper nTelos sbf file, then restore apps/settings from tibu?
    6. Is a nandroid backup essentially the same as an sbf, or would I need to flash a proper sbf, root, then restore from recovery?
    I think that will get me started. Btw, this forum is really the best!
    Phone specs:
    Milestone X (nTelos)
    System version: 4.5.604.MB809.ACG-nTelos.en.US
    Android version: GB 2.3.5
    Kernel version: 2.6.32.9-geadffa3mcbk83@il93lnxdroid08#1
    Build number: 4.5.1_57_MX2-34
    Themer
    Points: 9,882, Level: 66
    Level completed: 58%, Points required for next Level: 168
    Overall activity: 87.3%
    BHuber09's Avatar
    34670
    Atlantis
    3,300
    60 times
    I can answer 1 and 2
    1 roms are operating systems made by users and there are many of them and sbf iis a file that's made by the carrier to take the phone back to total stock. And there are only a few
    2 yes about 99.9% of your apps will work.
    FreeMyMoto!!!
    FreeMyMoto!!!
    If you need help PM me
    Points: 5,932, Level: 49
    Level completed: 91%, Points required for next Level: 18
    Overall activity: 1.8%
    spodoc's Avatar
    17924
    2,043
    88 times
    #5) to get back to out of box, perform a factory reset and then flash the appropriate sbf. Any apps that came pre installed will already be there.
    Points: 15,172, Level: 79
    Overall activity: 14.0%
    cory46's Avatar
    8051
    4,777
    125 times
    Quote Originally Posted by wvcadle View Post
    Questions follow:
    There is a kernel check you can disable to install on other carriers
    This is how your kernel version will/may vary
    ***How To Install CM4DX or MIUI on Milestone X***
    Milestone sbf
    http://sites.google.com/site/1kdsdro...ne-x-sbf-files
    Yep
    Sbf is a factory image. Or an out of the box like state. A Nandroid is a system snapshot when you made it. Think like a system restore point in Windows computers
    If you sbf from a Rom you can restore a Nandroid to return to a previous state as long as you're rooted
    And ninja'd as I was typing
    Points: 28,234, Level: 98
    Level completed: 89%, Points required for next Level: 116
    Overall activity: 99.9%
    Activity Award
    DirtyDroid's Avatar
    28665
    Upstate,NY
    9,433
    83 times
    Number 3 & 6...I think..
    3...its more device specific I believe
    6..yes a nandroid is in someway a way of not having to sbf....as its stock rooted...always nice to have...but there may be that time when you can't get in to restore...then sbf is necessary
    Ninjad
    wvcadle's Avatar
    53286
    Dec 2011
    86
    So, what roms are available for my Milestone X? What are the most popular, and stable roms?
    I was wanting to flash CyanogenMod, but have found (in the last 30 minutes) that there isn't a stable release for the Droid X yet.
    Phone specs:
    wvcadle's Avatar
    53286
    Dec 2011
    86
    Anyone? Liberty? CM? MIUI? Also, is it possible to flash custom themes without flashing a ROM?
    Phone specs:
    Activity Award
    DirtyDroid's Avatar
    28665
    Upstate,NY
    9,433
    83 times
    Check in Cory's post...I think miui and cm7 he posted
    wvcadle's Avatar
    53286
    Dec 2011
    86
    So which one is more stable? Have you flashed either of them?
    Phone specs:
    Points: 15,170, Level: 79
    Level completed: 64%, Points required for next Level: 180
    Overall activity: 53.8%
    The persuader's Avatar
    12986
    Maine
    5,444
    60 times
    As far as Stable...
    Awesome Choices...
    Miui 1.12.9
    Apex RC4
    Liberty 3
    Flashing them correctly is Key to Stabilty or any ROM for that matter...
    Its Bubba
    "Stubborn In You're Bones"
  1. Flashing a new ROM questions
    By duramax07 in forum Droid X2 Hacks
    Last Post: 11-16-2011, 02:09 PM
  2. Flashing ROMS over others
    By chuck54 in forum Droid X ROMs
    Last Post: 08-19-2011, 10:05 AM
  3. Going from OTA Gingerbread to flashing ROMs....a few questions
    By rlb in forum Gingerbread Development and Hacking
    Last Post: 06-19-2011, 04:54 AM
  4. Flashing roms to dx
    By veggiop in forum Droid X General Discussion
    Last Post: 04-07-2011, 02:44 AM
  5. flashing roms
    By droiding in forum Droid X Help
    Last Post: 01-01-2011, 08:12 PM
bootloader milestone x2
changing milestone x 4.5.604.mb809.acg-ntelos.en.us to cyanogenmod 7
droid x how to flash 3
droid x2 2.3.5 kernal 2.6.32.9 cant flash roms
droid x2, flash custom rom on 2.3.5
flahing to ntelos problem
how to flash roms on droid x
how to unbrick mb809 2.3.5
mb809 4.5.604 stuck in bootloader
mb809 stuck on boot loader
mb809.acg ntelos.en.us 2.2.1
milestone x2 2.3.5 rom
milestone x2 flash verizon
miui milestone x ntelos
restore droid x 4.5.604 original icons
