Questions on flashing roms and sbfs
This is a discussion on Questions on flashing roms and sbfs within the Droid X FAQs forums, part of the Droid X Discussion category; Do you have a preference? Reasons? Could you give me a little insight regarding flashing them 'correctly'?...
Results 11 to 20 of 26
Thread: Questions on flashing roms and sbfs
    Points: 2,090, Level: 27
    Level completed: 60%, Points required for next Level: 60
    wvcadle's Avatar
    53286
    Dec 2011
    89
    Phone specs:
    Milestone X (nTelos)
    System version: 4.5.604.MB809.ACG-nTelos.en.US
    Android version: GB 2.3.5
    Kernel version: 2.6.32.9-geadffa3mcbk83@il93lnxdroid08#1
    Build number: 4.5.1_57_MX2-34
    Advocate X Achievements:
    The persuader's Avatar
    12986
    Maine
    5,603
    66 times
    Not really, for me the ROM's Mention are really All Stable with me...
    Not just these choices with ROM's others as well, the Dev's do a Awesome Job trying to make sure any ROM they Release has the Performance and the least amount of issues. Yes, some that are Beta can be somewhat Interesting but its Still work in progress and Still Tweaking...Who cares its better then anything Ive ever done with ROM's so I don't complain...
    Now, One method I have and most do here as well, is to Nanodroid (Backup) to GB.602 so when ROM's request a SBF you can Restore back to .602 and Flash your ROM...
    I will also do...99.5% for the Time I will SBF from scratch without Nanodroiding and then Flash it as a New ROM then Nanodroid that ROM...
    If I notice its Buggy, Force Closes, not user Friendly floating from Screen to Screen, Locks up or even Rebooting on its own...I will Re-Flash the ROM...Making sure you do All your Wipes before flashing...
    Forces closes for the most part is Permissions requesting access to your App or just doesnt like the App period...I find this to be very infrequent...no worries
    Short verision...
    Most of Our Members can take this to another Level which may have more info...Great Forum and Awesome Members to resolve issues...
    Its Bubba
    Quote Originally Posted by wvcadle View Post
    "Stubborn In You're Bones"
    wvcadle's Avatar
    53286
    Dec 2011
    89
    Can you tell me which version is the most stable, but still has a working camera?
    Phone specs:
    12986
    Maine
    5,603
    66 times
    Hello my Friend,
    Seriously, I would suggest All that I mentioned...
    So you know...All the Camera's are working on any of the ROM's Mentioned, FX Zoom, Vigette, Stock, ...Yup...Even Stock works...
    The Versions are noted with the ROM of Choice...Try them all and you tell me which is the Best...mine is simple...All Of Them...
    Its Bubba
    Points: 22,755, Level: 93
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    For you I would suggest liberty first. Apex is for sure the most stable in my opinion but liberty will show you what rom'ing your phone is about.
    Any 2init roms are the least stable for example cm7
    That's just my opinion you just have to flash then all until you find your favorite.
    FreeMyMoto!!!
    FreeMyMoto!!!
    If you need help PM me!!!
    wvcadle's Avatar
    53286
    Dec 2011
    89
    Just remember, I have a Milestone X. Would either of those work on the Milestone X?
    Phone specs:
  8. #17
    12986
    Maine
    5,603
    66 times
    OK,
    If I were to chose one it would be Apex RC4. Hands Down
    Its Bubba
  9. #18
    wvcadle's Avatar
    53286
    Dec 2011
    89
    Quote Originally Posted by The persuader View Post
    As far as Stable...
    Awesome Choices...
    Miui 1.12.9
    Apex RC4
    Liberty 3
    Flashing them correctly is Key to Stabilty or any ROM for that matter...
    Its Bubba
    Ok, after many YouTube videos, I think I'm going to flash MIUI. Where can I get the 1.12.9 version?
    Phone specs:
  10. #19
    Points: 6,372, Level: 52
    Level completed: 11%, Points required for next Level: 178
    savagerun's Avatar
    41501
    2,204
    54 times
    Here [ROM] MIUI.us Defx 1.12.9
  11. #20
    wvcadle's Avatar
    53286
    Dec 2011
    89
    Please see the following 2 post thread [Q] nTelos Motorola Milestone X-Safe to flash latest Droid X MIUI build? - xda-developers. It was asked by someone with my exact situation (nTelos GB OTA 2.3.5 updated phone). The response stated that trying to flash a custom rom would brick the phone.
    Comments?
    Phone specs:
  1. Flashing a new ROM questions
    By duramax07 in forum Droid X2 Hacks
    Last Post: 11-16-2011, 03:09 PM
  2. Flashing ROMS over others
    By chuck54 in forum Droid X ROMs
    Last Post: 08-19-2011, 11:05 AM
  3. Going from OTA Gingerbread to flashing ROMs....a few questions
    By rlb in forum Gingerbread Development and Hacking
    Last Post: 06-19-2011, 05:54 AM
  4. Flashing roms to dx
    By veggiop in forum Droid X General Discussion
    Last Post: 04-07-2011, 03:44 AM
  5. flashing roms
    By droiding in forum Droid X Help
    Last Post: 01-01-2011, 09:12 PM
bootloader milestone x2
build number 4.5.1 57 mx2-34
build number 4.5.1 57 mx2-34 flash cricket
changing milestone x 4.5.604.mb809.acg-ntelos.en.us to cyanogenmod 7
droid x2, flash custom rom on 2.3.5
flash droid x to ntelos
flash mb809 to cricket
how to flash droid x to ntelos
how to flash roms on droid x
milestone x2 bootloader
