DROID X - Hard Keys
This is a discussion on DROID X - Hard Keys within the Droid X FAQs forums, part of the Droid X Discussion category; How do I use the hard keys on my phone? Front Keys Press Menu to open menu options (Add, Search, Wallpapers, Notifications, Settings) Press Home ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Like Tree5Likes
Thread: DROID X - Hard Keys
    Points: 55,862, Level: 100
    JimMariner's Avatar
    SE Fla, T-Bolt !!!
    663
    79 times
    DROID X - Hard Keys
    Front Keys
    Press Home to open your App tray, and also to close any menu / app and return to the home screen.
    • At a home screen, press and hold Home button to show the last few apps you used, then touch an app to open it.
    • Double-Tap on Home hard key for other functions. (See below)
    Press Back to go backwards (in your selections).
    Press Search for text search. Press and hold for Voice search.
    Power Key ( Sleep & Wake Up)
    To save your battery, prevent accidental taps, or when you want to wipe smudges off your touchscreen, put the touchscreen to sleep by pressing Power . To wake up the touchscreen, just press Power again, or open the phone.
    To change how long your phone waits before the screen goes to sleep automatically, press Menu > Settings > Sound & display > Screen timeout.
    Power key menu
    Press and hold Power to open the power key menu, where you can turn OFF the phone (Power off), or turn Airplane mode or Silent mode on or off. You can press the Home or Back hard key to back out of Power key menu.
    Home Button customization
    You can assign a DROID X handset function to the Home key as a "Double tap" function. Just double-tap on the Home hard key to activate the specifed function.
    To change the function from the home screen: Menu > Settings > Applications > Double tap home launch
    Select from Browser, Camera, Contacts, Dialer, Gmail, Happenings, Maps, Messaging, Music, News, SMS, Voice Command (default setting), Voice Search as features for Double tap home launch
    Source
    Points: 2,543, Level: 30
    Level completed: 62%, Points required for next Level: 57
    n0m0n's Avatar
    295
    HERE
    306
    Can these be changed to our choice for the double click the home button (like Power Strip).
    Or the long hold on the search button (like QuickDesk)?
    Thanks
    JW
    It is the mark of an educated mind is to be able to entertain a thought without accepting it.
    -- Aristotle
    Support P.E.T.A. [PEOPLE EATING TASTY ANIMALS]
    Points: 2,233, Level: 28
    Level completed: 56%, Points required for next Level: 67
    Overall activity: 1.8%
    DroidXXX's Avatar
    919
    214
    What is the little red hard key on the right hand edge side for?
    Droid X, Android version 2.3.3, System version 4.5.596 MB810
    blackngray70's Avatar
    215
    Georgia
    18
    Quote Originally Posted by DroidXXX View Post
    That's for the camera.
    DroidXXX's Avatar
    919
    214
    Quote Originally Posted by blackngray70 View Post
    Thanks!
    Tagger Second Class500 Experience Points250 Experience Points100 Experience Points7 days registered
    baniels's Avatar
    30
    52556
    369
    26 times
    I was thinking it would be nice if I could set the double tap of the home button to lock my screen.
    Points: 2,816, Level: 32
    Level completed: 44%, Points required for next Level: 84
    7 days registered250 Experience PointsCreated Album picturesThree Friends100 Experience Points
    ugadawg67's Avatar
    79
    The Big City of Rocky Face Georgia
    85
    Good info
    "Untutored courage is useless in the face of educated bullets."
    General Georgie Smith Patton
    Rhith's Avatar
    451
    41
    Thanks for this, forgot to change my double tap, takes me right to my messaging. Helpful because of all the texting I do.
    n0m0n's Avatar
    295
    HERE
    306
    So I guess Power Strip, and QuickDesk are no longer an option on a DX?
    Thanks
    JW
    -- Aristotle
    melrowgo's Avatar
    8885
    Is there a way to disable the "home key wake-up" feature? I'd rather not have the slide-to-unlock activated, but without it sometimes my Droid X turns itself on in my purse or tote. I want to be able to set the phone so that it will only turn on via the power button.
  1. Tip for anyone using a hard or silicone case
    By Garemlin in forum Droid X Accessories
    Last Post: 07-13-2010, 08:19 PM
Where is the menu button on the droid x
droid x buttons
droid x change buttons
droid x hard keys
droid x menu
droid x menu button
droid x menu hard key
droid x menu key
menu button droid x
menu button on droid x
menu key on droid x
where is menu button on droid x
where is menu on droid x
where is the menu button on droid x
where is the menu key on droid x
