DROID X - Factory Data Reset
This is a discussion on DROID X - Factory Data Reset within the Droid X FAQs forums, part of the Droid X Discussion category; How do I reset my phone to factory settings? Factory Data Reset is a tool used to remove everything that was imported, added or installed ...
Results 1 to 1 of 1
Thread: DROID X - Factory Data Reset
    Points: 59,147, Level: 100
    JimMariner's Avatar
    SE Fla, T-Bolt !!!
    663
    80 times
    Factory Data Reset is a tool used to remove everything that was imported, added or installed on the device.
    WARNING: When using this feature; information you have programmed in the handset is deleted, however, nothing stored on the MicroSD will be affected.
    To Perform a Reset
    1. Open the Applications Tray. (arrow pointing up located in the middle at the bottom of the display screen)
    2. Touch Settings
    3. Touch Privacy
    4. Touch Factory data reset
    5. Touch Reset Phone
    6. Touch Erase Everything
    Note: Please contact your Service provider to reset/clear your phone remotely if it is lost or stolen.
    To Manually Reset your handset through external key sequence, please contact your service provider or Motorola customer service.
    Source
  1. DROID X - Reset Pattern Lock / Passcode
    Last Post: 07-14-2010, 11:20 PM
droid x factory data reset
droid x factory reset
droid x reset
droidx factory reset
factory data reset droid x
factory reset droid x
how to factory reset Droid x
how to reset a droid x
how to reset droid x
motorola droid x factory data reset
