How to root? Also need GB ROM recommendations.
This is a discussion on How to root? Also need GB ROM recommendations. within the Droid X FAQs forums, part of the Droid X Discussion category; Hi everybody, I have experience rooting a Samsung Fascinate but I'm attempting to root a DX for the first time and this thing is kicking ...
Results 1 to 10 of 10
  • 1 Post By DirtyDroid
Thread: How to root? Also need GB ROM recommendations.
    Points: 91, Level: 1
    Level completed: 82%, Points required for next Level: 9
    Overall activity: 0.7%
    gravybiscuit's Avatar
    52110
    Nov 2011
    6
    Hi everybody,
    I have experience rooting a Samsung Fascinate but I'm attempting to root a DX for the first time and this thing is kicking my butt. I have followed two separate tutorials for restoring to factory defaults, rooting, loading alternate bootstrap and installing a GB ROM. All have ended up bombing out during the installation of the new ROM. Can anyone please direct me to a solid DX rooting tutorial / ROM install link? Also, could you please recommend a very clean and stable ROM to try? I attempted two different CM7 and an Apex ROM they didn't work out.
    Thank you very much for you help!
    Gravybiscuit
    Points: 28,234, Level: 98
    Level completed: 89%, Points required for next Level: 116
    Overall activity: 99.9%
    Activity Award
    DirtyDroid's Avatar
    28665
    Upstate,NY
    9,433
    83 times
    everything you will need is in here. assuming your on the latest .602 or .605 GB.602! ROOT! Start here! Links to all
    What kind of stable rom are you looking for? My personal pref. is miui 10.21 build, but Vortex, SSX, and CM7 are amazing also..
    heres a link to vortex Vortex
    52110
    Nov 2011
    6
    Thanks for the speedy reply DirtyD! I'm looking for a ROM that has great power management and is super clean, so I can load only what's necessary. What do you like about MIUI 10.21?
    Activity Award
    DirtyDroid's Avatar
    28665
    Upstate,NY
    9,433
    83 times
    power management as in battery life? What do i like about miui? the customization...is just simply amazing haha, granted it does have the "ios" feel, but put that with android and its spectacular imo...but i also have boot mangaer set up as well with , vortex, ssx, liquid, and liberty....and they are all amazing imo just depends on what rom i feel like running that day lol (side note) miui does take some getting used to tho
    52110
    Nov 2011
    6
    Yes, by power management I do mean battery life. The boot manager sounds pretty sweet. Does that just come with MIMU or did you load it after the fact? I think it sounds great, but I'm working on my wife's phone, and she's not too techy. In your opinion, which of the ROMs you use is balanced between speed, battery life, and ease of use?
    RS Team Leader
    Points: 19,414, Level: 88
    Level completed: 13%, Points required for next Level: 436
    Overall activity: 48.6%
    popcenator's Avatar
    21238
    Omaha, NE
    7,800
    112 times
    Vortex and Liberty are a couple of easy reliable ROMs, I'd check those out.
    Activity Award
    DirtyDroid's Avatar
    28665
    Upstate,NY
    9,433
    83 times
    Yeah Bootmanager is awsome...between all those, I would go with vortex imo...its truly an amazing rom for GB
    Edit: and like Pops said, you can't go wrong with LIberty either..
    52110
    Nov 2011
    6
    Much obliged boys. I will follow up after I finish. :-)
    52110
    Nov 2011
    6
    OMG! That was so much easier than the other tutorial instructions I had found. I simply rooted and left a copy of the VorteX ROM on the SD card to install using the D2 bootstrap. That was it! The other tutorials involved installing an SDK and setting the DX back to factory defaults etc. Is there a way to make the D2 bootstrap or Clockworkmod permanently take the place of the stock bootstrap?
    Again, I really appreciate your help! :-D
    52110
    Nov 2011
    6
  1. Smartphone recommendations
    By Fahszybear in forum Droid X General Discussion
    Last Post: 09-08-2011, 12:22 AM
  2. ROM recommendations?
    By WugFresh in forum Droid X ROMs
    Last Post: 03-17-2011, 10:41 PM
  3. ROM recommendations?
    By WugFresh in forum Droid X Hacks
    Last Post: 12-16-2010, 10:28 PM
  4. Car mount recommendations please
    By BAKDROIDX in forum Droid X Accessories Reviews
    Last Post: 10-26-2010, 08:01 AM
  5. Car charger recommendations
    By Androidrookie in forum Droid X Accessories
    Last Post: 07-21-2010, 09:47 PM
+mimu rom droid x download
can't root droid x gb
droid x gb roms
droid x gb rom
droid x gb rom root
droid x gb roms
droid x gb root rom
droid x liberty rom tutorial
droid x rom tutorials
how do you root gb on fascinate currently running gb
how to root gb
mimu andriod
mimu android
mimu droid x
mimu on droid x
mimu rom
mimu rom droid x
rom droid x gb
rooted gb roms for droidx
stock gb rom for rooted htc thunderbolt
