DROID X - Roadrunner Email
This is a discussion on DROID X - Roadrunner Email within the Droid X FAQs forums, part of the Droid X Discussion category; How can I setup Road Runner email? Roadrunner recomends to be connected to WiFi when setting up account. To setup Roadrunner on your DROID X ...
Results 1 to 1 of 1
Thread: DROID X - Roadrunner Email
    Points: 65,951, Level: 100
    JimMariner's Avatar
    SE Fla, T-Bolt !!!
    663
    82 times
    To setup Roadrunner on your DROID X once you have already set-up your handset, follow directions below. If you are adding Roadrunner account during your handset's initial startup, skip down to Set-up account menu (Instruction #3).
    1. Open Applications tray, touch My Accounts
    2. Select Add Account
    3. You will be at the Set-Up accounts menu with several other social network icons.
    4. Select Email icon
    5. Enter your full Roadrunner email address, including "@__.rr.com" domain name in all lower case.
    6. Enter Roadrunner password.
    7. Leave Automatically configure account checked.
    8. Tap on Next. Handset will connect to your email server and state "Success!" if account was set-up correctly.
    Your account is now set-up. Please test sending and receiving an email.
    Web Email access for Road Runner can be bookmarked with your phone's browser at Road Runner High Speed Online - Select your Web Mail server
    Manual setup Road Runner POP3 email on your DROIDx:
    Road Runner has multiple POP3 server names depending on your location. You can actually determine your POP3 server names from your Roadrunner email address. If your address is johndoe@satx.rr.com, then the POP3 server will be pop-server.satx.rr.com and the SMTP server will be smtp-server.satx.rr.com. If the address is johndoe@tampabay.rr.com then the POP3 server will be pop-server.tampabay.rr.com and the SMTP server will be smtp-server.tampabay.rr.com. At that point hopefully the port settings are consistent.
    3. Enter your full Roadrunner email address, including "@__.rr.com" domain name in all lower case.
    4. Enter Roadrunner password.
    5. Uncheck Automatically configure account.
    6. Tap on Next.
    7. Touch General Settings, confirm information in all General Settings fields are correct. Make any necessary changes, then select OK to exit this menu.
    8. Touch Incoming Server
    9. Touch POP mail server
    10. Enter POP3 server - pop-server.si.rr.com -(*** si refers to Staten Island; Search list at bottom of FAQ for the roadrunner server name for your location)
    11. Enter Port - 110
    12. Enter your username
    13. Enter your password
    14. Uncheck Use Secure server
    15. Uncheck Verify certificate
    16. Touch OK
    17. Select Outgoing server
    18. Enter SMTP server - smtp-server.si.rr.com - (*** si refers to Staten Island only; Search list at bottom of FAQ for the roadrunner server name for your location)
    19. Use Secure server unchecked
    20. Verify certificate is unchecked
    21. Enter Port - 587 (*** Port 25 can also be used for outgoing if 587 does not work)
    22. Touch OK
    23. Touch Other Settings,
    24. Select length of time messages will be kept on handset. (1 week, 2 weeks, 1 month, 2 months, Never Delete Messages)
    25. Tap on OK
    26. Tap on OK again to submit your email set-up.
    Your account is now set-up. Please test sending and receiving an email. You may need to go back and change Security settings on the account to send / receive email.
    CLICK HERE to learn more about customizing personal email settings.
    We have included the full list of Roadrunner's server names listed alphabetically acc'd to state.
    Scroll down or text search to identify the server name for your location
    ***Use information below to setup your Road Runner incoming email and outgoing email servers according to your location:
    Road Runner Internet Service Provider Email Setup Alabama (Birmingham)
    incoming mail server: pop-server.bham.rr.com
    outgoing mail server: smtp-server.bham.rr.com
    Road Runner Internet Service Provider Email Setup Alabama (Dothan)
    incoming mail server: pop-server.sw.rr.com
    outgoing mail server: smtp-server.sw.rr.com
    Road Runner Internet Service Provider Email Setup Alabama (Elmore)
    incoming mail server: pop-server.elmore.rr.com
    outgoing mail server: smtp-server.elmore.rr.com
    Road Runner Internet Service Provider Email Setup Alabama (Eufaula)
    incoming mail server: pop-server.eufaula.rr.com
    outgoing mail server: smtp-server.eufaula.rr.com
    Road Runner Internet Service Provider Email Setup California (Bakersfield)
    incoming mail server: pop-server.bak.rr.com
    outgoing mail server: smtp-server.bak.rr.com
    Road Runner Internet Service Provider Email Setup California (San Diego)
    incoming mail server: pop-server.san.rr.com
    outgoing mail server: smtp-server.san.rr.com
    Road Runner Internet Service Provider Email Setup California (Southern / Los Angeles)
    incoming mail server: pop-server.socal.rr.com
    outgoing mail server: smtp-server.socal.rr.com
    Road Runner Internet Service Provider Email Setup California (Desert Cities)
    incoming mail server: pop-server.dc.rr.com
    outgoing mail server: smtp-server.dc.rr.com
    Road Runner Internet Service Provider Email Setup Florida (Cantonment)
    incoming mail server: pop-server.panhandle.rr.com
    outgoing mail server: smtp-server.panhandle.rr.com
    Road Runner Internet Service Provider Email Setup Florida (Central Florida, Orlando)
    incoming mail server: pop-server.cfl.rr.com
    outgoing mail server: smtp-server.clf.rr.com
    Road Runner Internet Service Provider Email Setup Florida (Cape Coral / Naples)
    incoming mail server: pop-server.swfla.rr.com
    outgoing mail server: smtp-server.swfla.rr.com
    Road Runner Internet Service Provider Email Setup Florida (Lake City / Live Oak)
    incoming mail server: pop-server.se.rr.com
    outgoing mail server: smtp-server.se.rr.com
    Road Runner Internet Service Provider Email Setup Florida (Palatka)
    Road Runner Internet Service Provider Email Setup Florida (St. Augustine)
    Road Runner Internet Service Provider Email Setup Florida (Tampa Bay)
    incoming mail server: pop-server.tampabay.rr.com
    outgoing mail server: smtp-server.tampabay.rr.com
    Road Runner Internet Service Provider Email Setup Georgia (Ft. Benning)
    Road Runner Internet Service Provider Email Setup Hawaii (Hawaii)
    incoming mail server: pop-server.hawaii.rr.com
    outgoing mail server: smtp-server.hawaii.rr.com
    Road Runner Internet Service Provider Email Setup Indiana (Indianapolis)
    incoming mail server: pop-server.indy.rr.com
    outgoing mail server: smtp-server.indy.rr.com
    Road Runner Internet Service Provider Email Setup Indiana (Terre Haute)
    incoming mail server: pop-server.ma.rr.com
    outgoing mail server: smtp-server.ma.rr.com
    Road Runner Internet Service Provider Email Setup Kansas (Kansas City)
    incoming mail server: pop-server.kc.rr.com
    outgoing mail server: smtp-server.kc.rr.com
    Road Runner Internet Service Provider Email Setup Kansas (Colby)
    incoming mail server: pop-server.we.rr.com
    outgoing mail server: smtp-server.we.rr.com
    Road Runner Internet Service Provider Email Setup Louisiana (Houma)
    Road Runner Internet Service Provider Email Setup Louisiana (La Place)
    Road Runner Internet Service Provider Email Setup Louisiana (Monroe)
    incoming mail server: pop-server.jam.rr.com
    outgoing mail server: smtp-server.jam.rr.com
    Road Runner Internet Service Provider Email Setup Louisiana (Shreveport)
    incoming mail server: pop-server.sport.rr.com
    outgoing mail server: smtp-server.sport.rr.com
    Road Runner ISP Email Setup Maine (Southeast Maine, Portland)
    incoming mail server: pop-server.maine.rr.com
    outgoing mail server: smtp-server.maine.rr.com
    Road Runner ISP Email Setup Massachusettes (Athol)
    incoming mail server: pop-server.mass.rr.com
    outgoing mail server: smtp-server.mass.rr.com
    Road Runner ISP Email Setup Massachusettes (Berkshire County)
    incoming mail server: pop-server.berkshire.rr.com
    outgoing mail server: smtp-server.berkshire.rr.com
    Road Runner ISP Email Setup Michigan (Detroit)
    incoming mail server: pop-server.twmi.rr.com
    outgoing mail server: smtp-server.twmi.rr.com
    Road Runner ISP Email Setup Minnesota (Minneapolis)
    incoming mail server: pop-server.mn.rr.com
    outgoing mail server: smtp-server.mn.rr.com
    Road Runner ISP Email Setup Mississippi (Jackson)
    Road Runner ISP Email Setup Missouri (Kansas City)
    Road Runner ISP Email Setup Nebraska (Lincoln)
    incoming mail server: pop-server.neb.rr.com
    outgoing mail server: smtp-server.neb.rr.com
    Road Runner ISP Email Setup New Hampshire (Keene)
    incoming mail server: pop-server.ne.rr.com
    outgoing mail server: smtp-server.ne.rr.com
    Road Runner ISP Email Setup New Jersey (Bergen)
    incoming mail server: pop-server.nj.rr.com
    outgoing mail server: smtp-server.nj.rr.com
    Road Runner ISP Email Setup New York (Albany)
    incoming mail server: pop-server.nycap.rr.com
    outgoing mail
    Click here to go back to top
    Source
  1. DROID X - Email Set-up
    Last Post: 07-14-2010, 11:47 PM
droid x roadrunner email setup
how to set up a roadrunner email on a droid
how to set up roadrunner email on a droid
how to set up roadrunner email on droid
how to set up roadrunner email on droid x
how to set up rr email on droid
roadrunner droid x email setup
set up road runner email on droid
setting up roadrunner email on droid
