DROID X - Tips for extending battery life
This is a discussion on DROID X - Tips for extending battery life within the Droid X FAQs forums, part of the Droid X Discussion category; Are there any tips on how to extend the battery life? Things you should know about charging your battery. New batteries are not fully charged. ...
Like Tree3Likes
  • 3 Post By JimMariner
Thread: DROID X - Tips for extending battery life
    Points: 65,951, Level: 100
    JimMariner's Avatar
    SE Fla, T-Bolt !!!
    663
    82 times
    New batteries are not fully charged. Plug the battery charger into your phone and an electrical outlet. Your phone might take several seconds to start charging the battery.
    Tips:
    • The battery charger shipped with this device is a high rate charger specifically designed for your DROID X.
      Other chargers might take longer to charge your battery, cause your calls to fail during charging, or cause your phone to continuously power cycle.
    • You can charge your phone via USB cable but this charging time will vary based on computer specifications.
      If battery is low, your phone will not immediately power up when you connect it to a computer via USB. Depending on how low the battery is, it may take up to 30 minutes for the phone to get enough power to powerup.
    There are two built in tools to assist you in optimizing battery life.
    1. Power control widget
    The Power Control Widget gives you a quick snapshot of some of the tools that may be draining your battery. The widget can turn off / on several features: Wi-Fi, Bluetooth, Location (GPS), Synchronization, and also adjust Display brightness
    To add the Power control widget:
    From the home screen, touch Menu > (+)Add > Android Widgets > Power Control
    2. Battery Manager Feature
    The Battery Manager feature provides you with a real time view of what features or applications are using the highest percentage of your battery. It can also be used to select an automatic or manually-selected battery saving profile.
    To access Battery Manager:
    From the home screen, touch Menu > Settings > Battery Manager
    • Battery Profile: 3 automatic profiles - Performance (highest user of battery power), Smart (medium setting), and Battery Saver Mode (uses least amount of battery power)
    • Battery Profile Options: Manually select certain options to reduce battery usage.
    • Battery Use: provides current view of what features or applications are using the highest percentage of your battery
    Tips to extend battery life:
    • Select a shorter backlight duration
    • Lower the display brightness
    • Use the AC adapter to charge your phone whenever possible
    • Turn Bluetooth off when not in use
    • Turn Wi-Fi off when not in use
    • Certain applications may be drawing excessive battery power. If you are experiencing shorter battery life after downloading an application try uninstalling the application.
    • Close any third party applications running in the background
    • Playing music, videos and viewing images in your phone will affect your battery life.
    General Battery use & safety
    • Motorola recommends you always use Motorola-branded batteries and chargers. The warranty does not cover damage caused by non-Motorola batteries and/or chargers.
      Caution: Use of an unqualified battery or charger may present a risk of fire, explosion, leakage, or other hazard. Improper battery use, or use of a damaged battery, may result in a fire, explosion, or other hazard.
    • Your battery can be charged without it being fully depleted, and can be charged every day if desired.
    • Battery usage by children should be supervised.
    • Important: Motorola mobile devices are designed to work best with qualified batteries. If you see a message on your display such as Invalid Battery, Invalid Charger or Unable to Charge, take the following steps:
      • Remove the battery and inspect it to confirm that it bears a Motorola "Original Equipment" hologram;
      • If there is no hologram, the battery is not a qualified battery
      • If there is a hologram, replace the battery and retry charging it
      • If the message remains, contact a Motorola Authorized Service Center
    • New batteries or batteries stored for a long time may take more time to charge.
    • Charging precautions: When charging your battery, keep it near room temperature. Never expose batteries to temperatures below 0C (32F) or above 45C (113F) when charging. Always take your mobile device with you when you leave your vehicle
    • When storing your battery, keep it in a cool, dry place.
    • It is normal over time for battery life to decrease, and for the battery to exhibit shorter runtime between charges or require more frequent or longer charging times. Motorola batteries are designed to last between 350-700 charge/discharge cycles at room temperature. This amounts to approximately a year to a year and a half of battery use for most people.
    • Avoid damage to battery and mobile device. Do not disassemble, open, crush, bend, deform, puncture, shred, or submerge the battery or mobile device. Avoid dropping the battery or mobile device, especially on a hard surface. If your battery or mobile device has been subjected to such damage, take it to a local service center before using. Do not attempt to dry it with an appliance or heat source, such as a hair dryer or microwave oven.
    • Use care when handling a charged battery-particularly when placing it inside a pocket, purse, or other container with metal objects. Contact with metal objects (such as jewelry, keys, beaded chains) could complete an electrical circuit (short circuit), causing the battery to become very hot, which could cause damage or injury
    Source
    thud424, ebidar and Drewxd like this.
    7 days registered100 Experience Points
    Champin4's Avatar
    345
    44
    Thanks for the info about the charger, i was curious why it was.taking so long last night.. i was using a generic wall power to usb accessory
    Points: 2,026, Level: 27
    Level completed: 18%, Points required for next Level: 124
    PA452's Avatar
    8315
    116
    Is it best to wait until the battery is run down significantly before charging?
    My last phone I used to charge just about every night unless it was reading full power. And it never seemed to hurt anything leaving the charger on all night, even though it probably spent most of the night saying it was fully charged while I was sleeping.
    I know that can be bad for some rechargeable batteries. Anyone know the case with these phones/batteries?
    Thanks
    My new Droid X just gave me a popup that says "charge if battery is 75% down". I used to drain it all the way but I guess nowadays that's not needed. The popup said "modern day batteries". LOL. It came with one of those tips that you can read on one of the home screens.
    IIRC- The Droid X's battery is a type that does not really suffer from "memory"- you can run it down as much as you want. But for optimal performance, you should try your best not to let the battery fully discharge, you should try to keep the battery charged above 50%, and you should always charge the battery to 100% when you do charge. Of these, the biggest offender is probably letting the battery discharge repeatedly.
    The X also has a smart charging routine. I'm not sure on the specifics, but it's something like- the phone will charge itself to 100%, then won't pull any power until it hits 90%. Or... something.
    Short version- Charge the phone when it needs charge, and unless it's a major inconvenience for whatever reason, always charge it to 100% when you do.
  1. Extended Battery + Case?
    Last Post: 04-08-2011, 08:34 PM
  2. Droid X Poor Battery Life?
    By briankeith513X in forum Droid X General Discussion
    Last Post: 08-13-2010, 12:28 AM
  3. Replies: 39
    Last Post: 07-22-2010, 10:07 PM
  4. Tips on Apps
    By coasterman93 in forum Droid X General Discussion
    Last Post: 07-13-2010, 08:03 PM
driod keeps turning off battery complte discharge after being charged
droid charging tips
droid x battery doesnt last long
droid x battery life
droid x battery life tips
droid x short battery life
droid x2 battery life extension tips
droid x2 short battery life
how long does the droid x battery last
how to extend droid x2 battery life
