Froyo vs. Gingerbread
This is a discussion on Froyo vs. Gingerbread within the Droid X FAQs forums, part of the Droid X Discussion category; Im rooted with froyo 2.2.1 and I have really never had any problems.I froze my system update awhile ago before the root was possible for ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Froyo vs. Gingerbread
    Points: 382, Level: 7
    Level completed: 64%, Points required for next Level: 18
    Overall activity: 0.0%
    kody's Avatar
    43023
    Jul 2011
    6
    Im rooted with froyo 2.2.1 and I have really never had any problems.I froze my system update awhile ago before the root was possible for gingerbread. Can someone give me the skinny ie. Pros and cons of gingerbread before I update
    While some people have reported good luck with gingerbread on droid x, others, including myself, wish we never tried it. keep in mind, that VZ has cancelled the ability to upgrade from froyo to gingerbread on the DX, and its not available on the DX2 either.
    plus: hmm... I can automatically send a text message to someone when I hit the ignore on an inbound call.. my wireless tethering SEEMS to be active (without root, without paying VZ).
    I get less sales calls (actually, I get less calls. and emails, and texts'. ) all of the radio's seem borked.. I have to reset in between each time to use gps. i have to actively connect to my office/and home wifi now.
    25% less battery power, 25% less wifi range, 25% less 3g range.. I make 25% more mistakes on the kwybrd.[sic]. and it takes 25% more ram to run.
    25% more bloatware from VZ. and you can't root it once its installed.
    those are all the pluses I know about.
    I am, in fact, not even going to try to do a wipe/factory install.
    RS Team Leader
    Points: 19,414, Level: 88
    Level completed: 13%, Points required for next Level: 436
    Overall activity: 48.6%
    popcenator's Avatar
    21238
    Omaha, NE
    7,800
    112 times
    I had good luck with Gingerbread. If you do decide to update, use the two part prerooted install after an SBF. This will lay a clean foundation for Gingerbread and help minimize any issues you might have down the road. I thought it was very smooth and more responsive than Froyo, didn't seem to lag as much. The stock theme also was revamped with blue accents and a few more customizations.
    You also have a third option, CM7, which is installed directly from Froyo.
    Points: 1,986, Level: 26
    Level completed: 86%, Points required for next Level: 14
    Overall activity: 1.9%
    Bungle's Avatar
    1559
    180
    Quote Originally Posted by scheidell View Post
    This is not true statement number 1. I noticed a guy I work with in another building had the X and was on Froyo, told him about GB. He pulled it, installed it and loves it. This was just the other day. It was not been "cancelled"
    That doesn't mean anything. It's a different phone. And it's newer. They generally go in order of the phones release. The X2 is irrelevant.
    What is this 25% more bloat? I must have missed something. Only thing I recall (it's been MONTHS) is the downloads folder and a few other folders I actually find nice.
    Well there's your problem. Rather than take initiative and try to FIX what you are complaining about, you're more content to sit here and tell others not to update. Bravo.
    This post has been bothering me for some time. I just wanted to make sure GB was still "out in the wild" before replying.
    Points: 1,235, Level: 19
    Level completed: 35%, Points required for next Level: 65
    The Thrill's Avatar
    26916
    Ireland
    226
    Gingerbread is still kid of new, so a lot more problems might occur... But I still give credit to those developers.
    Points: 1,970, Level: 26
    Level completed: 70%, Points required for next Level: 30
    Overall activity: 3.6%
    selcric's Avatar
    36599
    539
    Quote Originally Posted by popcenator View Post
    +1 and now with MIUI I have, at this point in time, no desire at all to return to Froyo or Gingerbread...2nd init and not looking back.
    Points: 645, Level: 12
    Level completed: 90%, Points required for next Level: 5
    dahlheim's Avatar
    21835
    8
    happy with gb
    just installed gb several days ago (sbf to froyo, droid 2 bootstrapper to rooted gb install in recovery) and am very happy so far. i came from apex 1.3.1, which i left when newer apps updated from the market started to conflict.
    battery life has improved significantly. things are quite fast for me so far. and everything (wifi, gps, bluetooth) just works.
    Points: 536, Level: 10
    Level completed: 72%, Points required for next Level: 14
    AZDroid99's Avatar
    40533
    9
    I loved Froyo as well but I dont see any reason to wait...I'm on rooted GB now and really like it. Updated appearance like the clock/antenna are nice and the speed is def improved. I like how the animations are a little smoother (like when changing desktop screens).
    Titanium takes care of the bloat and Z4 to root. Adjbrightness app to turn off the bright physical buttons
    complaints are minor....I liked the old appearance of the contact list in Froyo and I dont like how text messaging has a white background in GB
    1st post!
    Points: 23,187, Level: 93
    Level completed: 84%, Points required for next Level: 163
    Overall activity: 100.0%
    Frequent Poster
    gbrinn's Avatar
    38696
    ECU
    9,009
    23 times
    Just looked into Adjbrightness and it seems to be hit or miss on the DX.
    Complete Droid-X SBF Flashing Guide
    GB 602 Root Starts Here
    Points: 1,304, Level: 20
    Level completed: 4%, Points required for next Level: 96
    mikec4's Avatar
    5253
    11
    I've used both and I got to say I think I honestly prefer FroYo with the Liberty 2.0.1 and Juiced Gingercomb. It's so clean looking and fast it's unreal. If these phones came like this stock they would be iphone killers not just in function but in sales.
  1. SBF from gingerbread to froyo 2.3.340
    By Harrison1 in forum Droid X SBF
    Last Post: 06-25-2011, 11:40 AM
  2. Froyo > Gingerbread
    By jblack2307 in forum Everything about Gingerbread
    Last Post: 06-06-2011, 01:17 PM
  3. Gingerbread 2.3 vs Froyo 2.2
    By Keuka79 in forum Gingerbread Development and Hacking
    Last Post: 05-26-2011, 04:54 AM
  4. froyo to .595 gingerbread
    By jing in forum Gingerbread Development and Hacking
    Last Post: 05-08-2011, 08:53 PM
  5. Android Gingerbread .588 >>> Froyo ?
    By jpisaniello in forum Droid X Help
    Last Post: 04-24-2011, 10:38 AM
difference between froyo and gingerbread
droid x froyo vs gingerbread
froyo gingerbread differences
froyo vs gingerbread differences
froyo vs gingerbread droid x
gingerbread pros and cons
gingerbread vs froyo
gingerbread vs froyo droid x
how to upgrade froyo to gingerbread
should i update from froyo to gingerbread
should i upgrade from froyo to gingerbread
update froyo to gingerbread
upgrading froyo to gingerbread
