Originally Posted by
Faithmusic
Will there anymore updates for the droid x?
As reported from DROID life there is in fact another update coming it is in the soak test phase right now and once we get it the system version will be 4.5.621 instead of 4.5.605 it is also said to fix numerous bugs.
Here's a link
http://www.droid-life.com/2012/02/17/droid-x-update-is-build-4-5-621-fixes-a-whole-bunch-of-bugs/
02-22-2012 08:20 AM
Latest update for those not following DROID life via twitter there are claims that if you take the update it will prevent you from flashing older firmware if you do you'll have a permanent paper weight
