How to Deal with a Droid thats Gotten Wet–THE RIGHT WAY
This is a discussion on How to Deal with a Droid thats Gotten Wet–THE RIGHT WAY within the Droid X FAQs forums, part of the Droid X Discussion category; From my blog How to Deal with a BlackBerry thats Gotten Wet–THE RIGHT WAY | Medic Three DISCLAIMER: YOUR PHONE MIGHT ALREADY BE GORKED. THIS ...
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 32
Like Tree12Likes
Thread: How to Deal with a Droid thats Gotten Wet–THE RIGHT WAY
    Points: 10,255, Level: 67
    Backnblack's Avatar
    26
    2,818
    138 times
    DISCLAIMER: YOUR PHONE MIGHT ALREADY BE GORKED. THIS IS JUST AN ATTEMPT TO GIVE YOU THE BEST ADVICE POSSIBLE TO FIX YOUR PHONE. IF THIS DOES NOT FIX YOUR PHONE, IT ISN’T MY FAULT. YOU’RE THE ONE WHO PIDDLED ON IT IN THE FIRST PLACE. NO, I DON’T NEED YOUR STORY ABOUT HOW RICE SAVED YOUR LIFE. I DON’T CARE THAT SOME COINCIDENCE HELPED. THIS IS THE PROPER PROCEDURE. LIVE WITH IT.
    Many of us have experienced the dreaded moment where our phone has met H2O up close and personal. Many of us have managed to salvage our devices too, sometimes with luck, sometimes with skill, sometimes purely on accident.
    There are many ideas out there on what to do: rice, water, alcohol, desiccant, etc. But the trouble is we don’t know why those reasons have worked for people, or if they have at all.
    Many here and all over the internet swear by using rice to draw out the moisture. While people have claimed to have great success with this method, there is no proof it is actually saving their device. How do we know that the phone didn’t just dry out on its own, given the proper time? The prinicipal behind rice is that it “draws” out the moisture. While yes, rice does absorb a great deal of moisture, its drawing power is very limited. There are no rice gnomes that sneak out of the rice and bring the moisture back for the rice gods.
    This leads us to Silica Desiccant. These are the little packets found in your shoe boxes, pill bottles, and many other packing materials. Obviously that tiny pack isn’t going to help, but you can get desiccant pouches at gun shops and craft stores sell loose desiccant used to dry flowers(it may just be labeled for such, not as desiccant). Silica desiccants do draw out moisture with great success. Far superior to rice, and best of all can be recharged in the oven on low-slow heat. Trouble is they only adsorb the water–not the crap the water brought with it.
    Often I have found that many people recommend rinsing with distilled water. The idea being that you are rinsing the impurities. While this is a good “idea”, you could just force more water into places we don’t want it! I think we forget that even though the phone was submerged water may not have made its way all the way into the phone and main board. You have then made a situation that would have dried out all on its own far worse.
    So… It takes a little thought on how to do this best. Despite all of the “this is what worked for me” stories, not ALL situations are the same. This might take a little critical thinking, and if you aren’t capable, just go ahead and call up Assurion and file your insurance claim. (PS, there is no guarantee you CAN salvage your phone, but these steps are your best bet).
    Step ONE:
    Expose your phone to water/liquid. Could be pee, could be a bottle of beer, could be both.
    Step TWO:
    Immediately remove battery. Do not pass go. Do not collect two hundred dollars. Do yourself a favor, take the battery, put it in a drawer and forget about it for a few days. The battery door can go with it, too.
    Step THREE:
    Using a soft towel pat the phone face down onto it. The keyboard is the major source for water entry into the phone. Allow gravity to work. Don’t try to turn it on now. Whatever you do, do NOT TRY TO TURN IT ON!
    Step FOUR:
    Go to the drug store and buy 100% rubbing alcohol(likely 91% might be the best you can find). Go to a well ventilated area with no spark risk. Away from your computer and tv too. Fill a bowl with enough alcohol(do not use liquor. do not use anything with coloring. THink about this… 80 proof liquor is only 40% alc, and has loads of other “stuff” in it. The very stuff we are trying to remove.) Take your phone, place gently in bowl, and lightly swish. Very gently . Remove from the bowl and repeat step THREE. Here it is in case your up arrow is broken:
    Quote:
    Step THREE:
    Step FIVE:
    This is the tough one. Wait. Wait until you think it is dry, then wait 2 more days. The alcohol that you rinsed your phone with displaced the water, now it must evaporate. There are risks to long term alcohol exposure for your phone–it can break seals(just like in people…) and break glue bonds. I’ve done this to 5 phones(not all mine, but for family/friends) and never experienced any alcohol related failures(the same can’t be said for their owners). I recommend waiting at least 4 days. 5 is better. I know, you can’t live without your phone for that long… but this is an attempt to save you some cash. Live with it.
    Step FIVE 1/2:
    Drying location. Some swear by rice. I wouldn’t put my phone it it. Short of a vacuum rice isn’t going to draw from the phone any more than it would the air. I find the best location is NEXT to an air conditioning vent or dehumidifier. Not on top of, not directly in line. We don’t want any forced air action, but the passive effects are great. If you must, you can use desiccant pouches. If you use loose, put it in a sock, and the phone in a sock, then put in the same close ziplock with the air sucked out. I would still allow the phone 24 hours to dry open air before giving it the desiccant treatment.
    Step SIX!!!!
    Put battery in. Watch closely to see if anything is different that before. Flashing, smoking, flames, and booms are all bad things. Normal is good. If it turns on completely, check EVERY button so you don’t have a surprise. If there is moisture under the screen, use DESICCANT from the gun shop/sporting goods store/craft store to draw it out. Follow instructions in Step Five using a ziplock bag–make sure to suck air out(or even better, a vaccuum packing machine). Test out your salvaged phone. If it works, rejoice!
    Alcohol is particularly helpful when the liquid was NOT water. It removes the sticky icky from your phone. That sticky icky really kills your keyboard. There is no guarantee you will save your phone this way, but this is the way I have saved 5 so far. This is also what we used in electronics assembly to clean delicate electronics for THESE signs. Some phones are beyond saving. This is a risk you take when you decide to attempt to save your piddle paddle phone. Live with it.
    Good luck. There are a million stories on the web about how to do this, but I promise you I have researched and have the electronics experience to do this the right way.
    Good Luck!
    Adapted from How to Deal with a BlackBerry thats Gotten Wet–THE RIGHT WAY | Medic Three | Medic Three
    Credit for this goes to Droid Forum - Verizon Droid & the Motorola Droid Forum - View Profile: medicTHREE
    Only the Skilled Survive
    1. Never be unarmed.
    2. See Rule #1
    Points: 2,557, Level: 30
    Level completed: 72%, Points required for next Level: 43
    3 months registered31 days registered250 Experience Points7 days registered100 Experience Points
    nojogray's Avatar
    3383
    Annapolis, Md
    67
    Thanks for this. I have heard a lot but nothing this in depth.
    Points: 1,955, Level: 26
    wmedina1991's Avatar
    1178
    377
    11 times
    this method can also be used on pc parts. I have done on motherboard that i got water from a busted water cooler on.
    DISCLAIMER: I take no responsibilty if something happens if you do something wrong, or God smites your board for listening to me.
    X Pursuant Achievements:
    Jaxidian's Avatar
    47
    Indianapolis
    694
    48 times
    FWIW, you should be careful with the screen when using chemicals (such as alcohol). You should avoid contact with the screen as much as possible. For the electronics, though, I agree.
    Points: 2,159, Level: 28
    Level completed: 6%, Points required for next Level: 141
    jedge's Avatar
    4079
    256
    35 times
    Thorough, well thought out advice.
    though it could have been about 1/2 as long without the snarky comments.
    Points: 4,469, Level: 42
    Level completed: 60%, Points required for next Level: 81
    BOWIE's Avatar
    1078
    Scottsdale, AZ
    603
    39 times
    Quote Originally Posted by Backnblack View Post
    EXCELLENT advice. You're the only other person I've seen on any of the phone forums who has a solid understanding of this and is not just compiling random (and questionable) advice. Good work man.
    nerdkill's Avatar
    4854
    27
    i'm confused. the x has no keyboard. is this just a generic fix across different models?
    Backnblack's Avatar
    26
    2,818
    138 times
    Quote Originally Posted by nerdkill View Post
    This works for any device. Was orginally written on the droid forum.
    2. See Rule #1
    Metalheadzaid's Avatar
    2319
    623
    39 times
    #1 rule is don't turn it $*%&ing on. BOLD LETTERS PLEASE. Biggest mistake people make.
    Since the Droid X doesn't have a keyboard it obviously means you have to use your computer's.
    Wheeler's Avatar
    4061
    26
    Good info, except for saying to suck the air out of the plastic bag. Desiccant doesn't suck moisture out of the device. It sucks moisure out of the air, and the drier air will suck more moisture out of the device (phone in this case).
    I work on slot machines for a living. Anything you can imagine gets dumped into those things, but it's usually beer. I use steps similar to these to fix most parts without having to replace anything.
    I also had 2 different Motorola clamshell phones submerged that worked perfectly afterwards.
  1. Bacon: The Real Deal (Or, Hello and All the Ways I can Say it)
    By Steve in forum New Member Introductions & Site Assistance
    Last Post: 08-02-2010, 09:20 PM
  2. Great deal on EBAY i found
    By JerryC in forum Droid X Accessories
    Last Post: 07-19-2010, 04:39 PM
droid 2 got wet
droid 2 wet
droid got wet screen not working
droid x got wet
droid x wet
dropped droid 2 in water
how to dry out a droid
my droid got wet
my droid x got wet
wet droid x
