[how to] turn autosync on/off
This is a discussion on [how to] turn autosync on/off within the Droid X FAQs forums, part of the Droid X Discussion category; WHAT IS AUTOSYNC? A setting which enables your phone to automatically fetch data in the background as you perform other tasks. This enables you to ...
Results 1 to 2 of 2
Like Tree2Likes
  • 2 Post By WugFresh
Thread: [how to] turn autosync on/off
    Advocate X
    Points: 24,548, Level: 95
    Overall activity: 31.6%
    WugFresh's Avatar
    19823
    Earth
    5,135
    455 times
    WHAT IS AUTOSYNC?
    A setting which enables your phone to automatically fetch data in the background as you perform other tasks. This enables you to get email notifications instantly, sync contact & calender changes instantly, and any sync data with any other apps you have which fetch data from a server.
    HOW TO TURN AUTOSYNC ON/OFF
    Option #1: Manually Change Setting
    For Custom ROMs:
    Contacts > Menu Button > Accounts > Check/Uncheck Autosync
    For Stock ROM:
    Menu button > settings > accounts and sync > Uncheck Autosync
    Option #2: Toggle Stock Power Widget
    Long press homescreen > Widgets > Power Control > Toggle the 4th button
    Option #3: Toggle Custom Widget
    Get Power Control Plus (widget) and make your own custom widget with an autosync toggle. The nice thing about Power Control Plus is gives you the option to integrate your custom widget into the pull-down notification menu for quick access.
    WHEN SHOULD YOU TURN AUTOSYNC OFF?
    • When you are tethering.
    • When you are having problems downloading.
    • When you are having a slow connection or difficulty browsing the web.
    • Whenever you are downloading a big file like a ROM.
    WHEN SHOULD YOU TURN AUTOSYNC ON?
    • When you are expecting emails.
    • When you want your calenders to sync
    • When you want your contacts to sync
    • When you want your news apps to sync
    • When you want Facebook to sync
    • When you want ANYTHING to sync
    Zzyyzx and mckeemichael1 like this.
    Other helpful resources:
    Superfly33's Avatar
    7587
    65
    Thanks for the heads up. How's your battery life with the autosync off?
  1. Google GPS. Any app for audible turn by turn?
    By set theorist in forum Droid X Apps
    Last Post: 07-03-2011, 11:20 AM
  2. Not Getting Turn by Turn w/ Google Maps
    By Corpsman in forum Droid X Help
    Last Post: 11-17-2010, 07:30 AM
  3. Replies: 3
    Last Post: 11-01-2010, 06:08 PM
  4. Replies: 0
    Last Post: 10-03-2010, 10:29 AM
  5. Turn by turn trip
    By Vinious in forum Droid X General Discussion
    Last Post: 08-13-2010, 02:37 PM
android 4.1.2 sync
droid x sync turn off
droid x turn off sync
how to turn off auto sync on droid x
how to turn off sync active on droid x
how to turn off sync on droid x
stop droid x from syncing
turn off auto sync droid x
turn off sync droid x
turn off sync on droid x2
