importing pictures?
This is a discussion on importing pictures? within the Droid X FAQs forums, part of the Droid X Discussion category; How the heck do I get my pics from my gallery onto my computer? When I plug my phone into my computer it comes up ...
Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By greevedogg
  • 1 Post By ryant35
Thread: importing pictures?
    Points: 5,026, Level: 45
    Level completed: 38%, Points required for next Level: 124
    Overall activity: 2.2%
    redwinger2001's Avatar
    734
    North Carolina
    380
    8 times
    importing pictures?
    How the heck do I get my pics from my gallery onto my computer? When I plug my phone into my computer it comes up and gives me the option to import my pics, but it only imports the pics that are in my 'files' folder, not the ones in my gallery. If I try to open my droid from 'my computer'(like a disk) there is no folder named gallery. I put my pics on flickr and i have about 200 pics on my phone. It would take me forever to upload each pic from my phone. Please tell me there is a way to get these pics from my phone onto my computer. HELP!
    Points: 5,624, Level: 48
    Level completed: 37%, Points required for next Level: 126
    Overall activity: 8.9%
    noXcuse's Avatar
    19040
    Chesapeake, Va.
    1,313
    59 times
    I always do it by just plugging in the USB and hitting import photos. When you plug it into the computer, you get a notification. Click on the notification, and make sure its set to USB Mass Storage.
    Or set the notification to PC Mode and go to my computer.
    The only other way I k ow to do it, is through WiFi in the DNLA program.
    Sent from my DROIDX
    734
    North Carolina
    380
    8 times
    once I did hit 'import photos' and it said it was importing, but after 3 hours....it said it was finished but my pics were nowhere to be found on my computer. Going to my computer when set in pc mode only shows me those pics that are in 'albums'. nowhere is there a file names gallery and my 200 pics aren't anywhere to be found either. haven't tried wifi in the dnla program. I don't even know what dnla means(lol). I don't have access to wifi this weekend, so I may try it when I do. Thanks for the response
    noXcuse's Avatar
    19040
    Chesapeake, Va.
    1,313
    59 times
    Wow. That's a long time to import. Go to search and type pictures on the computer.
    Sent from my DROIDX
    Points: 6,788, Level: 54
    Overall activity: 0.6%
    Created Album pictures31 days registered100 Experience Points7 days registeredTagger Second Class
    greevedogg's Avatar
    16608
    CFL
    477
    33 times
    plug your dx in to your comp, put it in usb mass storage mode, default folder should be: root of sd card>dcim>Camera
    check that out...
    there is a pretty cool app that i use to move files back and forth from pc to phone and vice-versa called 'Android Manager Wifi' ...it's free and you can browse your phone's files and transfer them over your homes wifi network without unmounting and mounting your sd card every time
    hope that helps...
    redwinger2001 likes this.
    734
    North Carolina
    380
    8 times
    Gonna give it a try...will report back soon. Thanks!
    Points: 9,280, Level: 64
    ryant35's Avatar
    7730
    SoCal
    1,706
    57 times
    Quote Originally Posted by greevedogg View Post
    Do this and select all and drag or copy to a folder on your PC. I just did this the other day to back up my photos after I noticed a few where disappearing. It did take around 10 min to copy 4gb of pictures and videos which is about right for USB.
    I've never liked import photo options, as a pro photographer I prefer to copy with windows explorer.
    734
    North Carolina
    380
    8 times
    You guys are awesome! The last two suggestions worked. I would have never found that file (dcim). Now will it disturb anything if I rename that folder to something I can recognize and remember?
    ryant35's Avatar
    7730
    SoCal
    1,706
    57 times
    Quote Originally Posted by redwinger2001 View Post
    Probably not, but I'll bet the phone will make a new dcim folder and save pictures there. You might be able to go though the camera settings and change the save location and possibly make a new folder.
    I have no problem remembering dcim because that is the fold created on all memory cards by all of the digital cameras I have owned.
  1. Importing Contacts (email address) Issue
    By crashintome in forum Droid X Help
    Last Post: 12-04-2010, 03:05 PM
  2. Pictures
    By Laydeeworeblak in forum Droid X Help
    Last Post: 11-20-2010, 12:29 PM
  3. Importing Contacts to Google with no SD card
    By shamy in forum Droid X Help
    Last Post: 08-25-2010, 02:13 PM
  4. importing the droid phone book to the car
    By ravis in forum Droid X General Discussion
    Last Post: 08-09-2010, 03:00 PM
  5. Pictures are gone?
    By smiley68 in forum Droid X Help
    Last Post: 07-19-2010, 04:13 PM
how do i import photos from my droidx to my
how do i import pictures from my droidx to my pc
how to import photos from droid to pc
how to import pictures from driod x to computer
how to import pictures from droid phone
how to import pictures from droid to computer
how to import pictures from droid x
how to import pictures from droid x2
import of photos from droid phone to the computer
where does the droid x2 import pictures to
