When I plug in my earphones to use and listen to the FM radio that is installed on my phone, the sound is super loud. I reduced the volume to the minimum but it is still too loud. Is there any way to reduce the sound on the FM radio? Thanks!
This is a discussion on FM Radio too loud within the Droid X Audio / Video forums, part of the Droid X Extras category; When I plug in my earphones to use and listen to the FM radio that is installed on my phone, the sound is super loud. ...
Have you tried different ear/headphones? Seems very strange to me your getting this problem since most other people need to increase the volume to the max for louder volume...
Try using alternative ear/headphones & get back to us.
http://www.youngbruno.com/
The same issue was present in the original Clip and it was fixed with a firmware update. Until the same happens with the Clip+, you can buy a headphone jack extension cord at Radio Shack with an in-line volume control on it for about 10 bucks.
