(ROOTED) How To:Change Boot Sound, Noise, Tone, or Whatever YOU may know it as
This is a discussion on (ROOTED) How To:Change Boot Sound, Noise, Tone, or Whatever YOU may know it as within the Droid X Audio / Video forums, part of the Droid X Extras category; Recently looking through all these forums trying to figure out how to change the noise my Droid X made when turning the device on I ...
Thread: (ROOTED) How To:Change Boot Sound, Noise, Tone, or Whatever YOU may know it as
    Points: 332, Level: 6
    Level completed: 64%, Points required for next Level: 18
    Overall activity: 1.5%
    250 Experience Points100 Experience Points31 days registered7 days registeredTagger Second Class
    440hi04's Avatar
    48271
    Sep 2011
    Ashtabula Ohio
    9
    Recently looking through all these forums trying to figure out how to change the noise my Droid X made when turning the device on I figured out how to do so Myself. Your Device Specifically is either set to make the "Droid" noise and when trying to change the notification ringtone you just get a series of beeps or something random. To successfully change the noise here is what you will need for starters:
    (Rooted) Droid X
    "RingDroid" (or any other program you prefer to use to make your custom tone)
    "MediaConverter" (paid app but I'm sure you could find it free somewhere if you can't pay for it)
    "Root Explorer" (of course or any other app you may want to use in place of this but this app works best)
    "Rom Toolbox" (optional until proven otherwise)
    1. To get started first you should go into "RingDroid" or whatever program you would like and make your tone. After making your custom tone save it and take note of where it was saved to. This step is important for Converting the file.
    2. Open "MediaConverter" and choose "Audio Converter". This should be the option on the Top Right. Click "Choose File". After choosing your file you will be back at the previous screen. On this screen you will see "Convert To Format". You will need to choose "OGG" which should be the second choice in the list. Only thing to do from there is tap "Convert!". Pay attention to where the file is located so you could it in the step to come.
    3. Here is where it is important to pay attention. Open up "Root Explorer" and on the top it should say "Mount R/W". Tap that to ensure everything works correctly. Remember in the previous step when i mentioned paying attention to where the file is located? Here is where that comes into play. Double check to make sure you know the location of that file before continuing. You should be able to locate the file by tapping "SDCard", then "Media", then "Audio" and finally "Ring Tones" or "Music" depending on where you chose to save it. After locating the file go back to the first page you saw when opening "Root Explorer" and tap on "System". From here tap "Media" and you will see "Audio" and your "Boot Animation". Tap "Audio" and on the next screen tap "Notifications". Find the file titled "Droid.ogg" and hold down (long press) on that file. A screen of Options will come up and you need to click "Move". Then you must click the back button on the bottom of your Droid X four times to get back to the first screen of the app. Tap "SDCard" and move the file to the same location as the file you created to be your new custom tone. Hold down on the file you just moved there ("Droid.ogg") and chose the option "Rename". Rename the file to something else besides "Droid.ogg". Keep the ".ogg" at the end of the name because that is the file type. After naming that file to something you will recognize, rename the file you created as your custom tone to "Droid.ogg". Afterwards, move the file into the folder where you got the original "Droid.ogg". Everything should be good to go from there. To ensure everything worked correctly in the same order I did things, I would recommend opening "Rom Toolbox", scroll down to "Wipe Dalvik-Cache" and tap that option. This should bring up a menu that says "Wipe Dalvik-Cache and reboot now?". Click "Yes" and everything should be history from there! Refer to the above writings for any questions you may have about the process that was not made completely clear. Any and all questions, comments, and concerns are welcome. Thank you again.
    Rescue Squad
    Points: 19,283, Level: 87
    Level completed: 87%, Points required for next Level: 67
    Overall activity: 61.4%
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    6,528
    90 times
    great post... i can think of a few times where i could have used this... very good write
    Post Script:
    We have nothing to fear but runnig out of beer
    don't mind me, I'm just falling
    Nemo Aeternamn Wallpapers
    Sbf: Linux - Rsd
    Common Terminolgy
    Root: Ginger
    Tether
    X2:Q&A+LINKS
    440hi04's Avatar
    48271
    Sep 2011
    Ashtabula Ohio
    9
    ​Thank you Nemo
    Themer
    Points: 3,718, Level: 38
    Level completed: 46%, Points required for next Level: 82
    Overall activity: 5.7%
    nemosfate's Avatar
    27305
    cincinnati
    1,080
    21 times
    Nice post 44, thanks for the tut
    root, roms and themes oh my!
  1. Replies: 35
    Last Post: 10-08-2011, 10:38 AM
  2. Replies: 16
    Last Post: 08-08-2011, 12:56 AM
  3. .588 boot sound change?
    By Scrapy McSlappy in forum Gingerbread Development and Hacking
    Last Post: 04-23-2011, 03:00 PM
  4. Change treble/bass/tone for call?
    By DLW3 in forum Droid X Help
    Last Post: 12-05-2010, 07:15 PM
  5. Ring tone / notification tone
    By Sean Wristen in forum Droid X Help
    Last Post: 08-18-2010, 08:48 AM
android boot sound
android boot sound change
android boot sounds
android startup sound
boot sound android
change android boot sound
change android startup sound
change boot sound android
change droid startup sound
droid x boot sound
droid x startup sound
how do i change the start up on my rooted droid x
how to change android boot sound
how to change boot sound on android
how to change ringtone on rooted android
