Quick Upload Problem
This is a discussion on Quick Upload Problem within the Droid X Audio / Video forums, part of the Droid X Extras category; Whenever I try and quick upload a photo, I get the message "Starting upload <*@gmail.com>" and then a "No default email account" message, and the ...
Results 1 to 9 of 9
Thread: Quick Upload Problem
    Points: 1,604, Level: 23
    Level completed: 4%, Points required for next Level: 96
    ClarkRU's Avatar
    2633
    28
    Whenever I try and quick upload a photo, I get the message "Starting upload <*@gmail.com>" and then a "No default email account" message, and the upload fails.
    Any ideas?
    ClarkRU, I'm having the same problem. Did you solve it?
    it appears for some odd reason this feature does not work with a Gmail account configured as a Google account. If I configure a "Email" account (or at least the SMTP side of one, including using smtp.googlemail.com config with a gmail account), it works fine. It kinda makes sense technically when you consider share includes both Gmail and Email (they're treated separately), but from a UI/UX side they should really let any Gmail/Email account on the device be used as the sending account.
    Points: 1,503, Level: 22
    Level completed: 3%, Points required for next Level: 97
    Led Zeppelin's Avatar
    4909
    Connecticut
    36
    I'm having this same problem. I try to use my gmail account for the quick upload, and it tells me "no default email account". So I can't use my gmail for quick upload? How do I configure another email address, such as my main Cox account, to be my default for quick uploads?
    ClarkRU's Avatar
    2633
    28
    I "solved" this by creating a picasa account and quick uploading to that. Works just as well i suppose.
    Points: 72, Level: 1
    Level completed: 44%, Points required for next Level: 28
    LoriMomof9's Avatar
    49966
    Oct 2011
    5
    I had to add my "email" in phone settings - accounts - email..... NOW it works again....
    Quote Originally Posted by jeremyjm View Post
    ...It kinda makes sense technically when you consider share includes both Gmail and Email (they're treated separately), but from a UI/UX side they should really let any Gmail/Email account on the device be used as the sending account.
    No it does not. Email, gmail, it's the same thing from the forest view. I should have to be a jedi to figure this out. Can someone please provide instructions for the neophite oxygen-breathing CO2 expelling lifeform that doesn't get this obviously intuitive application? Thanks! Because WTF, I just want to send a pic or two to a friendo or 3. Without all this jibber jabber.
    *&^(*R&Q)(W&E)(Q&WE)(*&.
    Points: 21, Level: 1
    Level completed: 41%, Points required for next Level: 29
    gmedia's Avatar
    53275
    Dec 2011
    Solution
    I just had the problem, and thought I'd post the solution here. Basically, you have to set up a NEW email (even though gmail and google apps emails ARE technically emails).
    What this program (the "gallery") requires is pop (or possibly imap) access. I set up a new gmail pop account (sort of duplicating my already entered google apps account).
    1. Click the "Menu Key"
    2. Click "Settings"
    3. Click "Accounts" towards the middle.
    4. Click "Add Account" at the bottom.
    5. Click "Email" towards the top of the list.
    6. Enter in your email login info. If it automatically configures it for you, great! If not, just enter the correct pop access info. gMail pop access found HERE. Make sure you go into the "Advanced Settings" for "Incoming" and "Outgoing" to enter in the correct port number, etc.
    7. Try to "Quick Upload" a picture to email. Make sure your email address is there to chose or type it in. You are done!
    Now, mine didn't work the first time, because my password was off. I think an error popped up on my screen to tel lme there was a connection error.
    I hope that helps!
    Chris
    Points: 71, Level: 1
    Level completed: 43%, Points required for next Level: 29
    Overall activity: 1.1%
    megancheung's Avatar
    57214
    14
    maybe it is not support gmail
  1. Youtube Upload Fails
    By baniels in forum Droid X Help
    Last Post: 05-12-2011, 04:43 PM
  2. ADW.Launcher problem adding Contact quick task widget
    By Nytewolfe in forum Droid X Apps
    Last Post: 10-09-2010, 12:05 PM
  3. Third Party Launcher w/Quick Contacts Quick Tasks
    By drose807 in forum Droid X Apps
    Last Post: 08-02-2010, 03:16 PM
  4. G4 quick video review of the X
    Last Post: 07-09-2010, 10:15 PM
android quick upload to email
droid quick upload
droid quick upload not working
droid quick upload settings
droid x quick upload
droid x quick upload error
droid x quick upload not working
droid x upload error
no default email account droid x
no default email account quick upload
quick upload android
quick upload droid x
quick upload no default email account
what is quick upload on droid x
