Battery App that adjusts for extended battery?
This is a discussion on Battery App that adjusts for extended battery? within the Droid X Apps forums, part of the Droid X Extras category; Lots of battery app threads out there but I haven't seen this question asked before. I have been using Battery Status Pro which provides an ...
Results 1 to 9 of 9
Thread: Battery App that adjusts for extended battery?
    Points: 6,551, Level: 53
    Level completed: 1%, Points required for next Level: 199
    B360155's Avatar
    217
    North Richland Hills, TX
    389
    32 times
    Lots of battery app threads out there but I haven't seen this question asked before. I have been using Battery Status Pro which provides an estimated time remaining. Apparently it has fixed times at 100% and then just calculates the time remaining by multiplying that number by whatever percentage is remaining on the battery. I picked up an extended life battery recently and when I check the estimated time remaining on a 100% charge using this app, the estimated times are exactly the same as with the standard battery. If you're swapping back and forth between the standard and the extended life battery, is there a battery app out there that has the ability to "know" which battery is currently installed in the phone and provide an estmated time remaining that's fairly accurate for whichever battery you're currently using?
    InfamousDX's Avatar
    435
    485
    16 times
    I think Battery Left has a dropdown for multiple battery profiles but I still never found that one to be particularly accurate, as I've said in many threads. But that's the only one I know that has the ability for multiple batteries.
    Rescue Squad
    Points: 42,712, Level: 100
    DebianDog's Avatar
    6359
    "The Sticks", Virginia
    4,384
    332 times
    I LOVE Battery Left but when I started running 2.2 with a battery saving profile it has TOTALLY messed up the calibration even after recalibrating it... twice.
    B360155's Avatar
    217
    389
    32 times
    Hmmmm...I installed the free version of Battery Left yesterday and it looks like it provides just the type of information that I was looking for and more. I'm in the process of calibrating the first battery, the extended life one. If I can get it to provide fairly accurate results, then I'll probably go ahead and purchase the pro version since it provides the multiple battery option and give it a whirl. Already uninstalled Battery Status Pro.
    Rescue Squad
    DebianDog's Avatar
    6359
    4,384
    332 times
    Yeah me too then I can "motivate" the developer as a paying customer.
    Having been a programer in a previous life I feel his pain on trying to calculate various battery saving modes.
    Points: 3,170, Level: 34
    Level completed: 80%, Points required for next Level: 30
    merovingian's Avatar
    6049
    Down the street
    168
    "batterylife" is pretty simple, from what i can tell it just reads the system info and makes it into a widget. It also shows temp and mV as well as batty type (Li-ion)
    someone does not like my signatures, though Benin and satirical, so i just dont have one...
    Praise "Bob"
    Rescue Squad
    DebianDog's Avatar
    6359
    4,384
    332 times
    Quote Originally Posted by merovingian View Post
    Battery LEFT not life
    The "problem" is now with 2.2 you can have battery profiles which will force the dev to calculate "what is left" differently
    dean2359's Avatar
    9008
    10
    Is there an app that can provide a visual indicator when the battery is finished charging? I cant believe the X doesn't have one,even my old droid 1 had a light on the side that changed to green. crazy
    31 days registered250 Experience Points7 days registered100 Experience PointsTagger Second Class
    dplsc01's Avatar
    241
    Indianapolis
    231
    21 times
    Quote Originally Posted by dean2359 View Post
    There is an app called Full Battery Alarm, that sets off an alarm when you battery is fully charged. That's the only app I found with a full charge indicator.
    Hope that helps.
  1. 30% off Extended Battery for Droid X
    By irod87 in forum Droid X Accessories
    Last Post: 04-18-2011, 11:13 PM
  2. Extended Battery! YES
    By msburr87 in forum Droid X Accessories
    Last Post: 09-03-2010, 03:48 PM
  3. Extended Battery?
    By z.snafu in forum Droid X General Discussion
    Last Post: 08-22-2010, 12:32 AM
  4. Extended Battery - Verizon has no idea what battery they're selling
    By shinjaejun in forum Droid X General Discussion
    Last Post: 08-19-2010, 10:29 PM
  5. Extended battery really 1930mAh??
    By OutGolfn in forum Droid X Accessories
    Last Post: 08-13-2010, 04:15 PM
android app for extended battery
android extended battery app
battery app for extended battery
best battery app for extended battery
extend battery app
extended battery app android
extra battery app
