Help with juice defender
This is a discussion on Help with juice defender within the Droid X Apps forums, part of the Droid X Extras category; Anyone use this, and us ut worth having? I got free version. Anybody with advice on which settings are the best and proper use would ...
Results 1 to 2 of 2
Thread: Help with juice defender
    dropd1us's Avatar
    22273
    paducah, ky
    74
    Anyone use this, and us ut worth having? I got free version. Anybody with advice on which settings are the best and proper use would be greatly appreciated. Seems like there has been a noticeable difference in battery. Could just be me though. I just set it to aggressive but don't quite understand the white list thing or what apps to chose as enabled at whhic percentage. Thanks.
    sent from DROIDX =C3..(COMMAND COMMUNICATE CONTROL)
    StephenX's Avatar
    16661
    77
    I used it for awhile, but then uninstalled it, because it got annoying having data turned off every time I shut off my screen. (I couldn't listen to pandora with the screen off, etc.) Didn't notice a huge difference in battery life. I maybe end up with 20% at the end of the day rather than 30%.
  1. Juice Defender Feedback
    By B360155 in forum Droid X Apps
    Last Post: 10-25-2010, 10:15 AM
  2. Juice Defender
    By obert272 in forum Droid X Apps
    Last Post: 08-31-2010, 08:36 AM
  3. Juice defender and set cpu does nothing?
    By jtdiddy in forum Droid X Apps
    Last Post: 08-25-2010, 02:54 PM
  4. Juice Defender
    By echof0xtrot in forum Droid X Apps
    Last Post: 08-25-2010, 10:29 AM
  5. Juice Defender
    By droidxer in forum Droid X Apps
    Last Post: 08-10-2010, 12:10 PM
how to use juice defender
juice defender aggresive
juice defender aggressive
juice defender agressive
juice defender forum
juice defender free settings
juice defender pandora
juice defender white list
juice defender whitelist
juicedefender aggressive
