i put the widget on the homepage, when i tap nothing happens? i have reinstalled and still have the same problem. any ideas? the regular app works though
This is a discussion on pandora widget problem within the Droid X Apps forums, part of the Droid X Extras category; i put the widget on the homepage, when i tap nothing happens? i have reinstalled and still have the same problem. any ideas? the regular ...
Where did you download the pandora widget? I'd try to help you but don't even see it listed in the market.
I was having the same problem. I found that if you tap the widget anywhere in the black it wont come on, you need to tap it right on the name. The pandaora should change to blue when you tap it.
hey, cool, i had no idea there was a pandora widget. i guess it comes with the app when you download it. i had the no response click problem at first, but it seems to work now. i just opened up pandora via the app and then the widget worked from then on, even when i deleted the app form the home screen. i just wish it didnt open pandora when you clicked the widget, rather only filled the widget with the buttons and info. is that because i totally close down pandora (menu -> quit) every time im done with pandora? does everyone do that? does it eat up memory/battery to just hit pause and go on with your day?
ever dance with the devil in the pale moonlight?
ya i figured it out thanks guys
i had the same problem...i just made a shortcut instead.
